#include <OgreMaterial.hh>
virtual ~OgreMaterial ()
virtual Ogre::MaterialPtr Material () const
virtual std::shared_ptr< const common::Image > NormalMapData () const override
 Get the normal map data. More...
virtual float RenderOrder () const override
virtual void SetAlphaFromTexture (bool _enabled, double _alpha=0.5, bool _twoSided=true) override
virtual void SetNormalMap (const std::string &_normalMap, const std::shared_ptr< const common::Image > &_img=nullptr) override
virtual void SetRenderOrder (const float _renderOrder) override
virtual void SetTexture (const std::string &_texture, const std::shared_ptr< const common::Image > &_img=nullptr) override
virtual std::shared_ptr< const common::Image > TextureData () const override
 Get the texture data. More...
- Public Member Functions inherited from BaseMaterial< OgreObject >
virtual ~BaseMaterial ()
double AlphaThreshold () const override
virtual void ClearLightMap () override
 Clone this material. More...
virtual std::shared_ptr< const common::Image > EmissiveMapData () const override
 Get the emissive map data. More...
virtual std::shared_ptr< const common::Image > EnvironmentMapData () const override
 Get the environment map data. More...
virtual bool HasLightMap () const override
virtual std::string LightMap () const override
virtual std::shared_ptr< const common::Image > LightMapData () const override
 Get the light map data. More...
virtual unsigned int LightMapTexCoordSet () const override
virtual std::shared_ptr< const common::Image > MetalnessMapData () const override
 Get the metalness map data. More...
virtual std::shared_ptr< const common::Image > RoughnessMapData () const override
 Get the roughness map data. More...
virtual void SetEmissiveMap (const std::string &_emissiveMap, const std::shared_ptr< const common::Image > &_img) override
virtual void SetEnvironmentMap (const std::string &_environmentMap, const std::shared_ptr< const common::Image > &_img) override
virtual void SetLightMap (const std::string &_lightMap, const std::shared_ptr< const common::Image > &_img, unsigned int _uvSet=0u) override
 Set the material light map from an image loaded in memory. More...
virtual void SetMetalness (const float _metalness) override
virtual void SetMetalnessMap (const std::string &_metalnessMap, const std::shared_ptr< const common::Image > &_img) override
virtual void SetRoughnessMap (const std::string &_roughnessMap, const std::shared_ptr< const common::Image > &_img) override
bool TextureAlphaEnabled () const override
bool TwoSidedEnabled () const override
virtual ~Material ()
virtual double AlphaThreshold () const =0
virtual std::string EmissiveMap () const =0
virtual std::shared_ptr< const common::Image > EmissiveMapData () const =0
virtual std::string EnvironmentMap () const =0
virtual std::shared_ptr< const common::Image > EnvironmentMapData () const =0
virtual bool HasEmissiveMap () const =0
virtual bool HasEnvironmentMap () const =0
virtual bool HasLightMap () const =0
virtual bool HasMetalnessMap () const =0
virtual bool HasRoughnessMap () const =0
virtual std::string LightMap () const =0
virtual std::shared_ptr< const common::Image > LightMapData () const =0
virtual unsigned int LightMapTexCoordSet () const =0
virtual float Metalness () const =0
virtual std::string MetalnessMap () const =0
virtual std::shared_ptr< const common::Image > MetalnessMapData () const =0
virtual float Roughness () const =0
virtual std::string RoughnessMap () const =0
virtual std::shared_ptr< const common::Image > RoughnessMapData () const =0
virtual void SetEmissiveMap (const std::string &_emissiveMap)
virtual void SetEnvironmentMap (const std::string &_environmentMap)
virtual void SetLightMap (const std::string &_lightMap, unsigned int _uvSet=0u)
virtual void SetMetalnessMap (const std::string &_metalnessMap)
virtual void SetNormalMap (const std::string &_normalMap)
virtual void SetRoughnessMap (const std::string &_roughnessMap)
virtual void SetTexture (const std::string &_texture)
virtual bool TextureAlphaEnabled () const =0
virtual bool TwoSidedEnabled () const =0
virtual enum MaterialType Type () const =0
 OgreMaterial ()
virtual Ogre::TexturePtr CreateTexture (const std::string &_name)
virtual void LoadOneImage (const std::string &_name, Ogre::Image &_image)
void SetTextureDataImpl (const std::string &_texture, const std::shared_ptr< const common::Image > &_img)
 Set the texture for this material from an image that was loaded from memory. More...
virtual void SetTextureImpl (const std::string &_texture)
 Set the texture for this material. More...
virtual Ogre::TexturePtr Texture (const std::string &_name)
virtual void UpdateColorOperation ()
void UpdateShaderParams ()
 bind shader parameters that have changed More...
void UpdateShaderParams (ConstShaderParamsPtr _params, Ogre::GpuProgramParametersSharedPtr _ogreParams)
 Transfer params from gz-rendering type to ogre type. More...
virtual void UpdateTransparency ()
- Protected Member Functions inherited from BaseMaterial< OgreObject >
 BaseMaterial ()
ShaderParamsPtr fragmentShaderParams
 Parameters to be bound to the fragment shader. More...
std::string fragmentShaderPath
 Path to fragment shader program. More...
std::shared_ptr< const common::Image > normalMapData
 Normal map image if it was passed as binary data. More...
std::string normalMapName
Ogre::String ogreGroup
Ogre::MaterialPtr ogreMaterial
Ogre::Pass * ogrePass = nullptr
Ogre::Technique * ogreTechnique = nullptr
Ogre::TextureUnitState * ogreTexState = nullptr
enum ShaderType shaderType = ST_PIXEL
std::shared_ptr< const common::Image > textureData
 Diffuse texture image if it was passed as binary data. More...
std::string textureName
ShaderParamsPtr vertexShaderParams
 Parameters to be bound to the vertex shader. More...
std::string vertexShaderPath
 Path to vertex shader program. More...
- Protected Attributes inherited from BaseMaterial< OgreObject >
double alphaThreshold
 Threshold for alpha channel rejection. More...
math::Color ambient
 Ambient color. More...
bool castShadows
bool depthCheckEnabled
bool depthWriteEnabled
math::Color diffuse
 Diffuse color. More...
math::Color emissive
 Emissive color. More...
bool lightingEnabled
bool receiveShadows
bool reflectionEnabled
double reflectivity
 Reflectivity. More...
double renderOrder
 Material render order. More...
double shininess
 Shininess factor. More...
math::Color specular
 Specular color. More...
bool textureAlphaEnabled
 Enable alpha channel based texture transparency. More...
double transparency
bool twoSidedEnabled
 Enable two sided rendering. More...
◆ OgreMaterial()
OgreMaterial ( )
◆ ~OgreMaterial()
virtual ~OgreMaterial ( )
◆ Ambient()
virtual math::Color Ambient ( ) const
The ambient color
Implements Material.
◆ CastShadows()
◆ ClearNormalMap()
Reimplemented from BaseMaterial< OgreObject >.
◆ ClearTexture()
virtual void ClearTexture ( )
◆ CreateTexture()
virtual Ogre::TexturePtr CreateTexture ( const std::string &  _name)
◆ DepthCheckEnabled()
◆ DepthWriteEnabled()
◆ Diffuse()
The diffuse color
◆ Emissive()
The emissive color
◆ FragmentShader()
◆ FragmentShaderParams()
editable parameters
◆ HasNormalMap()
◆ HasTexture()
◆ LightingEnabled()
virtual bool LightingEnabled ( ) const
◆ LoadOneImage()
virtual void LoadOneImage ( const std::string &  _name,
Ogre::Image &  _image
virtual Ogre::MaterialPtr Material ( ) const
◆ NormalMap()
◆ NormalMapData()
virtual std::shared_ptr<const common::Image> NormalMapData ( ) const
Pointer to the common::Image with the data if the texture was loaded from memory
◆ ReceiveShadows()
◆ ReflectionEnabled()
virtual bool ReflectionEnabled ( ) const
◆ Reflectivity()
virtual double Reflectivity ( ) const
The reflectivity value
◆ RenderOrder()
◆ SetAlphaFromTexture()
double  _alpha = 0.5,
bool  _twoSided = true
◆ SetAmbient()
virtual void SetAmbient ( const math::Color &  _color)
[in]_colorNew ambient color
◆ SetCastShadows()
virtual void SetCastShadows ( const bool  _castShadows)
◆ SetDepthCheckEnabled()
◆ SetDepthMaterial()
virtual void SetDepthMaterial ( const double  far,
const double  near
◆ SetDepthWriteEnabled()
◆ SetDiffuse()
[in]_colorNew diffuse color
◆ SetEmissive()
[in]_colorNew emissive color
◆ SetFragmentShader()
◆ SetLightingEnabled()
virtual void SetLightingEnabled ( const bool  _enabled)
◆ SetNormalMap()
virtual void SetNormalMap ( const std::string &  _normalMap,
const std::shared_ptr< const common::Image > &  _img = nullptr
[in]_normalMapURI of the new normal map file, or identifying name if map was set from raw data
[in]_imgImage data, nullptr if the image should be loaded from a file
◆ SetReceiveShadows()
◆ SetReflectionEnabled()
virtual void SetReflectionEnabled ( const bool  _enabled)
◆ SetReflectivity()
virtual void SetReflectivity ( const double  _reflectivity)
◆ SetRenderOrder()
◆ SetShaderType()
[in]_typeNew ShaderType value
◆ SetShininess()
virtual void SetShininess ( const double  _shininess)
◆ SetSpecular()
[in]_colorNew specular color
◆ SetTexture()
virtual void SetTexture ( const std::string &  _texture,
[in]_textureURI of the new texture file or identifying name if _img is set
◆ SetTextureDataImpl()
void SetTextureDataImpl ( const std::string &  _texture,
[in]_textureName of the texture.
[in]_imgcommon::Image containing the texture data
◆ SetTextureImpl()
virtual void SetTextureImpl ( const std::string &  _texture)
◆ SetTransparency()
◆ SetVertexShader()
◆ ShaderType()
The ShaderType value
◆ Shininess()
virtual double Shininess ( ) const
The shininess value
◆ Specular()
The specular color
◆ Texture() [1/2]
◆ Texture() [2/2]
virtual Ogre::TexturePtr Texture ( const std::string &  _name)
◆ TextureData()
virtual std::shared_ptr<const common::Image> TextureData ( ) const
◆ Transparency()
virtual double Transparency ( ) const
The transparency value
◆ UpdateColorOperation()
virtual void UpdateColorOperation ( )
◆ UpdateShaderParams() [1/2]
void UpdateShaderParams ( )
◆ UpdateShaderParams() [2/2]
void UpdateShaderParams ( ConstShaderParamsPtr  _params,
[in]_paramsGazebo Rendering params
[out]_ogreParamsogre type for holding params
◆ UpdateTransparency()
virtual void UpdateTransparency ( )
◆ VertexShader()
◆ VertexShaderParams()
editable parameters
◆ fragmentShaderParams
◆ fragmentShaderPath
◆ normalMapData
std::shared_ptr<const common::Image> normalMapData
◆ normalMapName
◆ ogreGroup
◆ ogreMaterial
◆ ogrePass
Ogre::Pass* ogrePass = nullptr
◆ ogreTechnique
Ogre::Technique* ogreTechnique = nullptr
◆ ogreTexState
Ogre::TextureUnitState* ogreTexState = nullptr
◆ shaderType
◆ textureData
std::shared_ptr<const common::Image> textureData
◆ textureName
◆ vertexShaderParams
◆ vertexShaderPath
