#include <BaseRenderEngine.hh>
virtual ~BaseRenderEngine ()
virtual void AddResourcePath (const std::string &_path) override
 Add path to media resource location. More...
virtual ScenePtr CreateScene (const std::string &_name) override
virtual ScenePtr CreateScene (unsigned int _id, const std::string &_name) override
virtual void DestroyScene (ScenePtr _scene) override
virtual void DestroySceneById (unsigned int _id) override
virtual void DestroySceneByIndex (unsigned int _index) override
virtual void DestroySceneByName (const std::string &_name) override
virtual void DestroyScenes () override
virtual bool Fini () override
virtual rendering::GraphicsAPI GraphicsAPI () const override
 Returns the GraphicsAPI currently in use. More...
virtual bool HasScene (ConstScenePtr _scene) const override
virtual bool HasSceneId (unsigned int _id) const override
virtual bool HasSceneName (const std::string &_name) const override
virtual bool Headless () const override
 Get headless mode. More...
virtual bool Init () override
virtual bool IsInitialized () const override
virtual bool IsLoaded () const override
virtual bool Load (const std::map< std::string, std::string > &_params={}) override
virtual RenderPassSystemPtr RenderPassSystem () const override
virtual ScenePtr SceneById (unsigned int _id) const override
virtual ScenePtr SceneByIndex (unsigned int _index) const override
virtual ScenePtr SceneByName (const std::string &_name) const override
virtual unsigned int SceneCount () const override
virtual void SetHeadless (bool _headless) override
- Public Member Functions inherited from RenderEngine
virtual ~RenderEngine ()
 BaseRenderEngine ()
virtual ScenePtr CreateSceneImpl (unsigned int _id, const std::string &_name)=0
virtual bool InitImpl ()=0
virtual bool LoadImpl (const std::map< std::string, std::string > &_params)=0
 Engine implementation of Load function. More...
virtual unsigned int NextSceneId ()
virtual void PrepareScene (ScenePtr _scene)
virtual SceneStorePtr Scenes () const =0
bool initialized = false
bool isHeadless = false
bool loaded = false
unsigned int nextSceneId
RenderPassSystemPtr renderPassSystem
 Render pass system for this render engine. More...
std::vector< std::string > resourcePaths
 a list of paths that render engines use to locate their resources More...
std::string winID = ""
 ID from a external window. More...
◆ BaseRenderEngine()
BaseRenderEngine ( )
◆ ~BaseRenderEngine()
virtual ~BaseRenderEngine ( )
◆ AddResourcePath()
virtual void AddResourcePath ( const std::string &  _path)
[in]_pathAbsolute path to resource location
Implements RenderEngine.
Reimplemented in Ogre2RenderEngine, and OgreRenderEngine.
◆ CreateScene() [1/2]
virtual ScenePtr CreateScene ( const std::string &  _name)
[in]_nameName of the new scene
The created scene
◆ CreateScene() [2/2]
virtual ScenePtr CreateScene ( unsigned int  _id,
[in]_idID of the new scene
The created scene
◆ CreateSceneImpl()
virtual ScenePtr CreateSceneImpl ( unsigned int  _id,
protectedpure virtual
Implemented in Ogre2RenderEngine, and OgreRenderEngine.
True if the render-engine was successfully destroyed
Reimplemented in OgreRenderEngine, and Ogre2RenderEngine.
◆ DestroyScene()
virtual void DestroyScene ( ScenePtr  _scene)
[in]_sceneScene to be destroyed
◆ DestroySceneById()
virtual void DestroySceneById ( unsigned int  _id)
[in]_idID of the scene to destroy
◆ DestroySceneByIndex()
virtual void DestroySceneByIndex ( unsigned int  _index)
[in]_indexIndex of the scene to destroy
◆ DestroySceneByName()
virtual void DestroySceneByName ( const std::string &  _name)
[in]_nameName of the scene to destroy
◆ DestroyScenes()
virtual void DestroyScenes ( )
◆ Fini()
virtual bool Fini ( )
◆ GraphicsAPI()
virtual rendering::GraphicsAPI GraphicsAPI ( ) const
inlineoverridevirtual
References gz::rendering::UNKNOWN.
◆ HasScene()
virtual bool HasScene ( ConstScenePtr  _scene) const
[in]_sceneScene in question
True if the scene is managed by this render-engine
◆ HasSceneId()
virtual bool HasSceneId ( unsigned int  _id) const
[in]_idID of scene in question
True if this render-engine manages the specified scene
◆ HasSceneName()
virtual bool HasSceneName ( const std::string &  _name) const
[in]_nameName of scene in question
◆ Headless()
virtual bool Headless ( ) const
Get headless mode.
virtual bool Init ( )
True if the render-engine was successfully initialized
◆ InitImpl()
virtual bool InitImpl ( )
◆ IsEnabled()
◆ IsInitialized()
virtual bool IsInitialized ( ) const
True if the render-engine is initialized
◆ IsLoaded()
virtual bool IsLoaded ( ) const
True if the render-engine is loaded
◆ Load()
virtual bool Load ( const std::map< std::string, std::string > &  _params = {})
[in]_paramsParameters to be passed to the underlying rendering engine.
True if the render-engine was successfully loaded
◆ LoadImpl()
virtual bool LoadImpl ( const std::map< std::string, std::string > &  _params)
◆ NextSceneId()
virtual unsigned int NextSceneId ( )
◆ PrepareScene()
virtual void PrepareScene ( ScenePtr  _scene)
◆ RenderPassSystem()
virtual RenderPassSystemPtr RenderPassSystem ( ) const
◆ SceneById()
virtual ScenePtr SceneById ( unsigned int  _id) const
[in]_idID of scene to be retrieved
The specified scene
◆ SceneByIndex()
virtual ScenePtr SceneByIndex ( unsigned int  _index) const
[in]_indexIndex of scene, which is a number from 0 to SceneCount() - 1. Note that the index for a specific scene might change as other scenes are destroyed.
The specified scene
◆ SceneByName()
virtual ScenePtr SceneByName ( const std::string &  _name) const
[in]_nameName of scene to be retrieved
The specified scene
◆ SceneCount()
virtual unsigned int SceneCount ( ) const
The number of active scenes
◆ Scenes()
virtual SceneStorePtr Scenes ( ) const
◆ SetHeadless()
virtual void SetHeadless ( bool  _headless)
◆ initialized
◆ isHeadless
◆ loaded
bool loaded = false
◆ nextSceneId
◆ renderPassSystem
◆ resourcePaths
std::vector<std::string> resourcePaths
◆ winID
