RenderEngine Class Referenceabstract
An abstract interface to a concrete render-engine. A RenderEngine is responsible for initializing a render-engine as well as creating, storing, and destroying scenes. More...
#include <gz/rendering/RenderEngine.hh>
virtual ~RenderEngine ()
virtual void AddResourcePath (const std::string &_path)=0
 Add path to media resource location. More...
virtual ScenePtr CreateScene (const std::string &_name)=0
virtual ScenePtr CreateScene (unsigned int _id, const std::string &_name)=0
virtual void DestroyScene (ScenePtr _scene)=0
virtual void DestroySceneById (unsigned int _id)=0
virtual void DestroySceneByIndex (unsigned int _index)=0
virtual void DestroySceneByName (const std::string &_name)=0
virtual void DestroyScenes ()=0
virtual bool Fini ()=0
virtual rendering::GraphicsAPI GraphicsAPI () const =0
 Returns the GraphicsAPI currently in use. More...
virtual bool HasScene (ConstScenePtr _scene) const =0
virtual bool HasSceneId (unsigned int _id) const =0
virtual bool HasSceneName (const std::string &_name) const =0
virtual bool Headless () const =0
 Get headless mode. More...
virtual bool Init ()=0
virtual bool IsInitialized () const =0
virtual bool IsLoaded () const =0
virtual bool Load (const std::map< std::string, std::string > &_params={})=0
virtual RenderPassSystemPtr RenderPassSystem () const =0
virtual ScenePtr SceneById (unsigned int _id) const =0
virtual ScenePtr SceneByIndex (unsigned int _index) const =0
virtual ScenePtr SceneByName (const std::string &_name) const =0
virtual unsigned int SceneCount () const =0
virtual void SetHeadless (bool _headless)=0
◆ ~RenderEngine()
virtual ~RenderEngine ( )
◆ AddResourcePath()
virtual void AddResourcePath ( const std::string &  _path)
[in]_pathAbsolute path to resource location
Implemented in Ogre2RenderEngine, OgreRenderEngine, and BaseRenderEngine.
◆ CreateScene() [1/2]
virtual ScenePtr CreateScene ( const std::string &  _name)
[in]_nameName of the new scene
The created scene
Implemented in BaseRenderEngine.
◆ CreateScene() [2/2]
virtual ScenePtr CreateScene ( unsigned int  _id,
[in]_idID of the new scene
The created scene
True if the render-engine was successfully destroyed
Implemented in OgreRenderEngine, Ogre2RenderEngine, and BaseRenderEngine.
◆ DestroyScene()
virtual void DestroyScene ( ScenePtr  _scene)
[in]_sceneScene to be destroyed
◆ DestroySceneById()
virtual void DestroySceneById ( unsigned int  _id)
[in]_idID of the scene to destroy
◆ DestroySceneByIndex()
virtual void DestroySceneByIndex ( unsigned int  _index)
[in]_indexIndex of the scene to destroy
◆ DestroySceneByName()
virtual void DestroySceneByName ( const std::string &  _name)
[in]_nameName of the scene to destroy
◆ DestroyScenes()
virtual void DestroyScenes ( )
◆ Fini()
virtual bool Fini ( )
◆ GraphicsAPI()
virtual rendering::GraphicsAPI GraphicsAPI ( ) const
◆ HasScene()
virtual bool HasScene ( ConstScenePtr  _scene) const
[in]_sceneScene in question
True if the scene is managed by this render-engine
◆ HasSceneId()
virtual bool HasSceneId ( unsigned int  _id) const
[in]_idID of scene in question
True if this render-engine manages the specified scene
◆ HasSceneName()
virtual bool HasSceneName ( const std::string &  _name) const
[in]_nameName of scene in question
◆ Headless()
virtual bool Headless ( ) const
Get headless mode.
virtual bool Init ( )
True if the render-engine was successfully initialized
◆ IsEnabled()
◆ IsInitialized()
virtual bool IsInitialized ( ) const
True if the render-engine is initialized
◆ IsLoaded()
virtual bool IsLoaded ( ) const
True if the render-engine is loaded
◆ Load()
virtual bool Load ( const std::map< std::string, std::string > &  _params = {})
[in]_paramsParameters to be passed to the underlying rendering engine.
True if the render-engine was successfully loaded
◆ Name()
◆ RenderPassSystem()
virtual RenderPassSystemPtr RenderPassSystem ( ) const
◆ SceneById()
virtual ScenePtr SceneById ( unsigned int  _id) const
[in]_idID of scene to be retrieved
The specified scene
◆ SceneByIndex()
virtual ScenePtr SceneByIndex ( unsigned int  _index) const
[in]_indexIndex of scene, which is a number from 0 to SceneCount() - 1. Note that the index for a specific scene might change as other scenes are destroyed.
The specified scene
◆ SceneByName()
virtual ScenePtr SceneByName ( const std::string &  _name) const
[in]_nameName of scene to be retrieved
The specified scene
◆ SceneCount()
virtual unsigned int SceneCount ( ) const
The number of active scenes
◆ SetHeadless()
virtual void SetHeadless ( bool  _headless)
