BaseWideAngleCamera< T > Class Template Reference
#include <BaseWideAngleCamera.hh>
virtual ~BaseWideAngleCamera ()
virtual common::ConnectionPtr ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
virtual void CreateWideAngleTexture ()
virtual const CameraLens & Lens () const override
 Get the camera lens used by this wide angle camera. More...
virtual math::Vector3d Project3d (const math::Vector3d &_pt) const override
 Project 3D world coordinates to screen coordinates. More...
virtual void SetLens (const CameraLens &_lens) override
 Set the camera lens to use for this wide angle camera. More...
- Public Member Functions inherited from WideAngleCamera
virtual ~WideAngleCamera ()
virtual ~Camera ()
virtual void Render ()=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
virtual ~BaseCamera ()
 BaseCamera ()
CameraLens lens
 Camera lens used by this wide angle camera. More...
 Anti-aliasing. More...
double aspect = 1.3333333
 Aspect ratio. More...
double farClip = 1000.0
NodePtr followNode
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseWideAngleCamera()
◆ ~BaseWideAngleCamera()
◆ ConnectNewWideAngleFrame()
common::ConnectionPtr ConnectNewWideAngleFrame ( std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberNew camera listener callback
Implements WideAngleCamera.
Reimplemented in OgreWideAngleCamera.
◆ CreateWideAngleTexture()
◆ Lens()
const CameraLens & Lens ( ) const
Camera lens set to this wide angle camera
◆ Project3d()
math::Vector3d Project3d ( const math::Vector3d &  _pt) const
[in]_pt3D world coodinates
Screen coordinates. Z is the distance of point from camera optical center.
◆ SetLens()
void SetLens ( const CameraLens &  _lens)
[in]_lensCamera lens to set
◆ lens
CameraLens lens
