WideAngleCamera Class Referenceabstract
Wide angle camera class. More...
#include <WideAngleCamera.hh>
virtual ~WideAngleCamera ()
virtual common::ConnectionPtr ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
virtual const CameraLens & Lens () const =0
 Get the camera lens used by this wide angle camera. More...
virtual math::Vector3d Project3d (const math::Vector3d &_pt) const =0
 Project 3D world coordinates to screen coordinates. More...
virtual void SetLens (const CameraLens &_lens)=0
 Set the camera lens to use for this wide angle camera. More...
virtual ~Camera ()
virtual void Render ()=0
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format)=0
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
gz/rendering/WideAngleCamera.hh
◆ ~WideAngleCamera()
virtual ~WideAngleCamera ( )
◆ ConnectNewWideAngleFrame()
virtual common::ConnectionPtr ConnectNewWideAngleFrame ( std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberNew camera listener callback
Implemented in OgreWideAngleCamera, BaseWideAngleCamera< T >, and BaseWideAngleCamera< OgreSensor >.
◆ Lens()
virtual const CameraLens& Lens ( ) const
Camera lens set to this wide angle camera
Implemented in BaseWideAngleCamera< T >.
◆ Project3d()
virtual math::Vector3d Project3d ( const math::Vector3d &  _pt) const
[in]_pt3D world coodinates
Screen coordinates. Z is the distance of point from camera optical center.
◆ SetLens()
virtual void SetLens ( const CameraLens &  _lens)
[in]_lensCamera lens to set
Implemented in BaseWideAngleCamera< T >, and BaseWideAngleCamera< OgreSensor >.
