Ogre implementation of WideAngleCamera. More...
#include <OgreWideAngleCamera.hh>
virtual ~OgreWideAngleCamera ()
common::ConnectionPtr ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Create a texture. More...
unsigned int EnvTextureSize () const
 Gets the environment texture size. More...
std::vector< Ogre::Camera * > OgreEnvCameras () const
 Get the list of ogre cameras used to create the cube map for generating the wide angle camera image. More...
 Render the camera. More...
math::Vector3d Project3d (const math::Vector3d &_pt) const override
 Project 3D world coordinates to screen coordinates. More...
bool SetBackgroundColor (const math::Color &_color)
 Set the background color of the camera. More...
void SetEnvTextureSize (int _size)
 Sets environment texture size. More...
void SetUniformVariables (Ogre::Pass *_pass, float _ratio, float _hfov)
 Set uniform variables of a shader for the provided material technique pass. More...
 Set visibility mask. More...
- Public Member Functions inherited from BaseWideAngleCamera< OgreSensor >
virtual ~BaseWideAngleCamera ()
virtual const CameraLens & Lens () const override
 Get the camera lens used by this wide angle camera. More...
virtual void SetLens (const CameraLens &_lens) override
 Set the camera lens to use for this wide angle camera. More...
- Public Member Functions inherited from WideAngleCamera
virtual ~WideAngleCamera ()
virtual const CameraLens & Lens () const =0
virtual ~Camera ()
 Sensor. More...
 Get visibility mask. More...
virtual ~BaseCamera ()
virtual ~OgreSensor ()
virtual ~BaseSensor ()
virtual ~OgreNode ()
void CreateCamera ()
 Create the camera. More...
void CreateEnvCameras ()
 Creates a set of 6 cameras pointing in different directions. More...
void CreateWideAngleTexture () override
 Set the camera's render target. More...
void notifyMaterialRender (Ogre::uint32 _pass_id, Ogre::MaterialPtr &_material) override
 Callback that is used to set mapping material uniform values, implements Ogre::CompositorInstance::Listener interface. More...
- Protected Member Functions inherited from BaseWideAngleCamera< OgreSensor >
 BaseCamera ()
virtual RenderTargetPtr RenderTarget () const=0
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
- Protected Attributes inherited from BaseWideAngleCamera< OgreSensor >
CameraLens lens
 Camera lens used by this wide angle camera. More...
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreWideAngleCamera()
OgreWideAngleCamera ( )
◆ ~OgreWideAngleCamera()
virtual ~OgreWideAngleCamera ( )
◆ ConnectNewWideAngleFrame()
common::ConnectionPtr ConnectNewWideAngleFrame ( std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberNew camera listener callback
Reimplemented from BaseWideAngleCamera< OgreSensor >.
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateEnvCameras()
void CreateEnvCameras ( )
◆ CreateRenderTexture()
Create a texture.
◆ CreateWideAngleTexture()
void CreateWideAngleTexture ( )
Reimplemented from OgreNode.
◆ EnvTextureSize()
unsigned int EnvTextureSize ( ) const
Texture size
◆ notifyMaterialRender()
void notifyMaterialRender ( Ogre::uint32  _pass_id,
Ogre::MaterialPtr &  _material
overrideprotected
[in]_pass_idPass identifier
[in]_materialMaterial whose parameters should be set
◆ OgreEnvCameras()
std::vector<Ogre::Camera *> OgreEnvCameras ( ) const
A list of OGRE cameras
◆ PostRender()
virtual void PostRender ( )
Render the camera.
◆ Project3d()
math::Vector3d Project3d ( const math::Vector3d &  _pt) const
[in]_pt3D world coodinates
Screen coordinates. Z is the distance of point from camera optical center.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
◆ SetBackgroundColor()
bool SetBackgroundColor ( const math::Color &  _color)
[in]_colorColor to set the background to
True if the background color is set successfully, false otherwise
◆ SetEnvTextureSize()
void SetEnvTextureSize ( int  _size)
[in]_sizeTexture size
◆ SetUniformVariables()
void SetUniformVariables ( Ogre::Pass *  _pass,
float  _ratio,
float  _hfov
[in]_passOgre::Pass used for rendering
[in]_ratioFrame aspect ratio
[in]_hfovHorizontal field of view
◆ SetVisibilityMask()
[in]_maskVisibility mask
Reimplemented from BaseSensor< OgreNode >.
