Base render pass that can be applied to a render target.
More...
#include <BaseRenderPass.hh>
| virtual | ~BaseRenderPass () |
| | Destructor. More...
| virtual bool | IsEnabled () const override |
| | Get whether or not the render pass is enabled. More...
| virtual void | SetEnabled (bool _enabled) override |
| | Set to enable or disable the render pass. More...
| virtual | ~RenderPass () |
| | Destructor. More...
| | Destructor. More...
| bool | enabled = true |
| | Flag to indicate if render pass is enabled or not. More...
template<class T>
class gz::rendering::BaseRenderPass< T >
◆ BaseRenderPass()
◆ ~BaseRenderPass()
◆ IsEnabled()
- Returns
- True if the render pass is enabled, false otherwise.
Implements RenderPass.
◆ SetEnabled()
| void SetEnabled |
bool |
_enabled | ) |
overridevirtual |
| [in] | _enabled | True to enable the render pass, false to disable. |
◆ enabled
