Ogre2GaussianNoisePass Class Reference
Ogre2 Implementation of a Gaussian noise render pass. More...
#include <Ogre2GaussianNoisePass.hh>
 Ogre2GaussianNoisePass ()
virtual ~Ogre2GaussianNoisePass ()
void PreRender () override
- Public Member Functions inherited from BaseGaussianNoisePass< Ogre2RenderPass >
virtual ~BaseGaussianNoisePass ()
double Bias () const
 Accessor for bias. More...
double Mean () const
 Accessor for mean. More...
void SetBiasMean (double _biasMean)
 Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
void SetBiasStdDev (double _biasStdDev)
 Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
void SetMean (double _mean)
 Set mean. More...
void SetStdDev (double _stdDev)
 Set stddev. More...
double StdDev () const
 Accessor for stddev. More...
- Public Member Functions inherited from GaussianNoisePass
virtual ~GaussianNoisePass ()
virtual double Bias () const =0
virtual double Mean () const =0
virtual double StdDev () const =0
virtual ~RenderPass ()
- Public Member Functions inherited from Ogre2RenderPass
virtual ~Ogre2RenderPass ()
void Destroy () override
std::string OgreCompositorNodeDefinitionName () const
 Get the ogre compositor node definition name for this render pass. More...
- Public Member Functions inherited from BaseRenderPass< Ogre2Object >
virtual ~BaseRenderPass ()
- Protected Member Functions inherited from BaseGaussianNoisePass< Ogre2RenderPass >
void SampleBias ()
- Protected Member Functions inherited from Ogre2RenderPass
 Ogre2RenderPass ()
- Protected Member Functions inherited from BaseRenderPass< Ogre2Object >
 BaseRenderPass ()
virtual void Init ()
- Protected Attributes inherited from BaseGaussianNoisePass< Ogre2RenderPass >
double bias
 Gaussian noise bias. More...
double biasMean
 The mean of the Gaussian distribution from which bias values are drawn. More...
double biasStdDev
 The standard deviation of the Gaussian distribution from which bias values are drawn. More...
double mean
 Gaussian noise mean. More...
double stdDev
 Standard deviation of Gaussian noise. More...
- Protected Attributes inherited from Ogre2RenderPass
std::string ogreCompositorNodeDefName
 Name of the ogre compositor node definition. More...
- Protected Attributes inherited from BaseRenderPass< Ogre2Object >
bool enabled
🔗Ogre2GaussianNoisePass()
🔗~Ogre2GaussianNoisePass()
virtual ~Ogre2GaussianNoisePass ( )
🔗CreateRenderPass()
void CreateRenderPass ( )
Reimplemented from Ogre2RenderPass.
🔗PreRender()
void PreRender ( )
