BaseGaussianNoisePass< T > Class Template Reference
Base Gaussian noise render pass. More...
#include <BaseGaussianNoisePass.hh>
| virtual | ~BaseGaussianNoisePass () |
| Destructor. More... | |
| double | Bias () const |
| Accessor for bias. More... | |
| double | Mean () const |
| Accessor for mean. More... | |
| void | SetBiasMean (double _biasMean) |
| Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
| void | SetBiasStdDev (double _biasStdDev) |
| Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
| void | SetMean (double _mean) |
| Set mean. More... | |
| void | SetStdDev (double _stdDev) |
| Set stddev. More... | |
| double | StdDev () const |
| Accessor for stddev. More... | |
Public Member Functions inherited from GaussianNoisePass | |
| GaussianNoisePass () | |
| Constructor. More... | |
| virtual | ~GaussianNoisePass () |
Public Member Functions inherited from RenderPass | |
| virtual | ~RenderPass () |
| virtual bool | IsEnabled () const =0 |
| virtual void | SetEnabled (bool _enabled)=0 |
| BaseGaussianNoisePass () | |
| void | SampleBias () |
Protected Attributes | |
| double | bias = 0.0 |
| Gaussian noise bias. More... | |
| double | biasMean = 0 |
| The mean of the Gaussian distribution from which bias values are drawn. More... | |
| double | biasStdDev = 0 |
| The standard deviation of the Gaussian distribution from which bias values are drawn. More... | |
| double | mean = 0.0 |
| Gaussian noise mean. More... | |
| double | stdDev = 0.0 |
| Standard deviation of Gaussian noise. More... | |
template<class T>
class gz::rendering::BaseGaussianNoisePass< T >
◆ BaseGaussianNoisePass()
protected |
◆ ~BaseGaussianNoisePass()
virtual |
◆ Bias()
virtual |
◆ Mean()
virtual |
◆ SampleBias()
protected |
◆ SetBiasMean()
virtual |
- See also
- SetBiasStdDev
Implements GaussianNoisePass.
◆ SetBiasStdDev()
virtual |
- See also
- SetBiasMean
◆ SetMean()
virtual |
◆ SetStdDev()
virtual |
Set stddev.
[in] _stdDev Standard deviation of Gaussian noise.
◆ StdDev()
virtual |
◆ bias
protected |
◆ biasMean
protected |
◆ biasStdDev
protected |
◆ mean
protected |
◆ stdDev
protected |
