#include <GaussianNoisePass.hh>
GaussianNoisePass () | |
Constructor. More... | |
virtual | ~GaussianNoisePass () |
Destructor. More... | |
virtual double | Bias () const =0 |
Accessor for bias. More... | |
virtual double | Mean () const =0 |
Accessor for mean. More... | |
virtual void | SetBiasMean (double _biasMean)=0 |
Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
virtual void | SetBiasStdDev (double _biasStdDev)=0 |
Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More... | |
virtual void | SetMean (double _mean)=0 |
Set mean. More... | |
virtual void | SetStdDev (double _stdDev)=0 |
Set stddev. More... | |
virtual double | StdDev () const =0 |
Accessor for stddev. More... | |
virtual | ~RenderPass () |
virtual bool | IsEnabled () const =0 |
Get whether or not the render pass is enabled. More... | |
virtual void | SetEnabled (bool _enabled)=0 |
Set to enable or disable the render pass. More... | |
virtual | ~Object () |
virtual void | Destroy ()=0 |
🔗GaussianNoisePass()
🔗~GaussianNoisePass()
virtual |
🔗Bias()
pure virtual |
🔗Mean()
pure virtual |
🔗SetBiasMean()
pure virtual |
- See also
- SetBiasStdDev
Implemented in BaseGaussianNoisePass< T >, BaseGaussianNoisePass< OgreRenderPass >, and BaseGaussianNoisePass< Ogre2RenderPass >.
🔗SetBiasStdDev()
pure virtual |
- See also
- SetBiasMean
🔗SetMean()
pure virtual |
Set mean.
[in] _mean Mean of Gaussian noise.
🔗SetStdDev()
pure virtual |
Set stddev.
[in] _stdDev Standard deviation of Gaussian noise.
🔗StdDev()
pure virtual |
- Returns
- Standard deviation of Gaussian noise.
Implemented in BaseGaussianNoisePass< T >.
