Ogre2RenderPass Class Reference
#include <Ogre2RenderPass.hh>
| virtual | ~Ogre2RenderPass () |
| Destructor. More... | |
| virtual void | CreateRenderPass () |
| Create the render pass using ogre compositor. More... | |
| void | Destroy () override |
| std::string | OgreCompositorNodeDefinitionName () const |
| Get the ogre compositor node definition name for this render pass. More... | |
Public Member Functions inherited from BaseRenderPass< Ogre2Object > | |
| virtual | ~BaseRenderPass () |
| virtual bool | IsEnabled () const override |
| virtual void | SetEnabled (bool _enabled) override |
Public Member Functions inherited from RenderPass | |
| virtual | ~RenderPass () |
| virtual bool | IsEnabled () const =0 |
| virtual | ~Ogre2Object () |
| virtual | ~BaseObject () |
| Ogre2RenderPass () | |
| Constructor. More... | |
Protected Member Functions inherited from BaseRenderPass< Ogre2Object > | |
| BaseRenderPass () | |
| Ogre2Object () | |
| BaseObject () | |
| virtual void | Init () |
| virtual void | Load () |
Protected Attributes | |
| std::string | ogreCompositorNodeDefName |
| Name of the ogre compositor node definition. More... | |
Protected Attributes inherited from BaseRenderPass< Ogre2Object > | |
| bool | enabled |
| Flag to indicate if render pass is enabled or not. More... | |
| Ogre2ScenePtr | scene |
| unsigned int | id |
| std::string | name |
The ogre2 compositor chain in gz-rendering is set up as follows:
- Base scene pass -> [0..N] RenderPass'es -> Final compositor pass. This is set up by Ogre2RenderTarget which loads the compositor workspace definiton from script. The base scene pass node is responsible for rendering the initial scene and passes its output to any RenderPass'es that are added to the RenderTarget. Each RenderPass has its own ogre compositor node that receives the output from the previous RenderPass as input, applies its own pass over the input, and sends the result to the next RenderPass. Note that the Ogre2RenderPass class provides the node definition only and the actual node creation work is done in the Ogre2RenderTarget class when the whole workspace is constructed.
◆ Ogre2RenderPass()
protected |
◆ ~Ogre2RenderPass()
virtual |
◆ CreateRenderPass()
virtual |
Reimplemented in Ogre2GaussianNoisePass.
◆ Destroy()
overridevirtual |
◆ OgreCompositorNodeDefinitionName()
| std::string OgreCompositorNodeDefinitionName | ( | ) | const |
◆ ogreCompositorNodeDefName
protected |
