RayQuery Class Referenceabstract
#include <gz/rendering/RayQuery.hh>
virtual ~RayQuery ()
virtual RayQueryResult ClosestPoint (bool _forceSceneUpdate=true)=0
 Get ray direction. More...
 Get ray origin. More...
 Set ray direction. More...
virtual void SetFromCamera (const CameraPtr &_camera, const math::Vector2d &_coord)=0
 Set ray origin. More...
◆ ~RayQuery()
virtual ~RayQuery ( )
◆ ClosestPoint()
virtual RayQueryResult ClosestPoint ( bool  _forceSceneUpdate = true)
[in]_forceSceneUpdatePerformance optimization hint When true Ogre2 will update all derived transforms to their latest to get correct results.
When false, that step is skipped. It is only safe to set it to false when nothing has changed since the last update (i.e. nothing moved, no new objects created).
Ogre will assert if built in Debug mode if this value is set to false when it shouldn't be.
See https://ogrecave.github.io/ogre-next/api/2.2/ _ogre20_changes.html::AssersionCachedOutOfDate for more info
Implemented in BaseRayQuery< T >, BaseRayQuery< Ogre2Object >, BaseRayQuery< OgreObject >, OgreRayQuery, and Ogre2RayQuery.
◆ Direction()
Get ray direction.
Ray direction.
Implemented in BaseRayQuery< T >.
◆ Origin()
virtual math::Vector3d Origin ( ) const
Get ray origin.
Ray origin
◆ SetDirection()
Set ray direction.
[in]_dirRay origin
Implemented in BaseRayQuery< T >, BaseRayQuery< Ogre2Object >, and BaseRayQuery< OgreObject >.
◆ SetFromCamera()
◆ SetOrigin()
virtual void SetOrigin ( const math::Vector3d &  _origin)
Set ray origin.
[in]_originRay origin
