#include <BaseRayQuery.hh>
virtual RayQueryResult ClosestPoint (bool _forceSceneUpdate=true) override
 Get ray direction. More...
 Get ray origin. More...
 Set ray direction. More...
virtual void SetFromCamera (const CameraPtr &_camera, const math::Vector2d &_coord) override
 Set ray origin. More...
virtual ~RayQuery ()
 BaseRayQuery ()
math::Vector3d direction
 Ray direction. More...
 Ray origin. More...
template<class T>
class gz::rendering::BaseRayQuery< T >
gz/rendering/base/BaseRayQuery.hh
◆ BaseRayQuery()
BaseRayQuery
◆ ~BaseRayQuery()
~BaseRayQuery
◆ ClosestPoint()
RayQueryResult ClosestPoint ( bool  _forceSceneUpdate = true)
[in]_forceSceneUpdatePerformance optimization hint When true Ogre2 will update all derived transforms to their latest to get correct results.
When false, that step is skipped. It is only safe to set it to false when nothing has changed since the last update (i.e. nothing moved, no new objects created).
Ogre will assert if built in Debug mode if this value is set to false when it shouldn't be.
See https://ogrecave.github.io/ogre-next/api/2.2/ _ogre20_changes.html::AssersionCachedOutOfDate for more info
Implements RayQuery.
Reimplemented in OgreRayQuery, and Ogre2RayQuery.
◆ Direction()
gz::math::Vector3d Direction ( ) const
Get ray direction.
Ray direction.
◆ Origin()
gz::math::Vector3d Origin ( ) const
Get ray origin.
Ray origin
◆ SetDirection()
Set ray direction.
[in]_dirRay origin
◆ SetFromCamera()
void SetFromCamera ( const CameraPtr &  _camera,
◆ SetOrigin()
void SetOrigin ( const math::Vector3d &  _origin)
Set ray origin.
[in]_originRay origin
◆ direction
Ray direction.
◆ origin
Ray origin.
