#include <Ogre2RayQuery.hh>
virtual ~Ogre2RayQuery ()
virtual RayQueryResult ClosestPoint (bool _forceSceneUpdate=true)
virtual void SetFromCamera (const CameraPtr &_camera, const math::Vector2d &_coord)
- Public Member Functions inherited from BaseRayQuery< Ogre2Object >
 Get ray direction. More...
 Get ray origin. More...
 Set ray direction. More...
 Set ray origin. More...
virtual ~RayQuery ()
 Ogre2RayQuery ()
- Protected Member Functions inherited from BaseRayQuery< Ogre2Object >
 BaseRayQuery ()
virtual void Init ()
- Protected Attributes inherited from BaseRayQuery< Ogre2Object >
math::Vector3d direction
 Ray direction. More...
 Ray origin. More...
gz/rendering/ogre2/Ogre2RayQuery.hh
◆ Ogre2RayQuery()
Ogre2RayQuery ( )
◆ ~Ogre2RayQuery()
virtual ~Ogre2RayQuery ( )
◆ ClosestPoint()
virtual RayQueryResult ClosestPoint ( bool  _forceSceneUpdate = true)
[in]_forceSceneUpdatePerformance optimization hint When true Ogre2 will update all derived transforms to their latest to get correct results.
When false, that step is skipped. It is only safe to set it to false when nothing has changed since the last update (i.e. nothing moved, no new objects created).
Ogre will assert if built in Debug mode if this value is set to false when it shouldn't be.
See https://ogrecave.github.io/ogre-next/api/2.2/ _ogre20_changes.html::AssersionCachedOutOfDate for more info
Reimplemented from BaseRayQuery< Ogre2Object >.
◆ SetFromCamera()
