| virtual | ~DepthCamera () |
| | Destructor. More...
| virtual gz::common::ConnectionPtr | ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0 |
| | Connect to the new depth image signal. More...
| virtual gz::common::ConnectionPtr | ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0 |
| | Connect to the new rgb point cloud signal. More...
| virtual void | CreateDepthTexture ()=0 |
| | Create a texture which will hold the depth data. More...
| virtual const float * | DepthData () const =0 |
| | All things needed to get back z buffer for depth data. More...
| virtual | ~Camera () |
| | Destructor. More...
| | Preforms any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
| virtual void | RenderTextureMetalId (void *_textureIdPtr) const =0 |
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
