#include <BaseStorage.hh>
 BaseStore ()
virtual ~BaseStore ()
virtual UIter Begin ()
virtual void DestroyAll ()
virtual UIter End ()
virtual void RemoveAll ()
virtual ~Store ()=default
UStore store
◆ BaseStore()
◆ ~BaseStore()
~BaseStore
◆ Add()
bool Add ( TPtr  _object)
True if successful
Implements Store< T >.
References std::endl(), and gzerr.
◆ AddDerived()
bool AddDerived ( UPtr  _object)
◆ AddImpl()
bool AddImpl ( UPtr  _object)
◆ Begin()
BaseStore< T, U >::UIter Begin
Iterator to beginning
◆ ConstIter()
BaseStore< T, U >::ConstUIter ConstIter ( ConstTPtr  _object) const
◆ ConstIterById()
BaseStore< T, U >::ConstUIter ConstIterById ( unsigned int  _id) const
◆ ConstIterByIndex()
BaseStore< T, U >::ConstUIter ConstIterByIndex ( unsigned int  _index) const
References std::advance(), std::endl(), and gzerr.
◆ ConstIterByName()
BaseStore< T, U >::ConstUIter ConstIterByName ( const std::string &  _name) const
◆ Contains()
◆ ContainsId()
◆ ContainsName()
◆ DerivedById()
BaseStore< T, U >::UPtr DerivedById ( unsigned int  _id) const
◆ DerivedByIndex()
BaseStore< T, U >::UPtr DerivedByIndex ( unsigned int  _index) const
◆ DerivedByName()
BaseStore< T, U >::UPtr DerivedByName ( const std::string &  _name) const
void Destroy ( TPtr  _object)
◆ DestroyAll()
void DestroyAll ( )
◆ DestroyById()
◆ DestroyByIndex()
◆ DestroyByName()
◆ DestroyImpl()
void DestroyImpl ( UIter  _iter)
◆ End()
BaseStore< T, U >::UIter End
Iterator to end
◆ GetById()
BaseStore< T, U >::TPtr GetById ( unsigned int  _id) const
The specified element
◆ GetByIndex()
BaseStore< T, U >::TPtr GetByIndex ( unsigned int  _index) const
◆ GetByName()
BaseStore< T, U >::TPtr GetByName ( const std::string &  _name) const
◆ IsValidIter()
◆ Iter()
BaseStore< T, U >::UIter Iter ( ConstTPtr  _object)
◆ IterById()
BaseStore< T, U >::UIter IterById ( unsigned int  _id)
◆ IterByIndex()
BaseStore< T, U >::UIter IterByIndex ( unsigned int  _index)
◆ IterByName()
BaseStore< T, U >::UIter IterByName ( const std::string &  _name)
◆ Remove()
BaseStore< T, U >::TPtr Remove ( TPtr  _object)
The removed element
◆ RemoveAll()
void RemoveAll ( )
◆ RemoveById()
BaseStore< T, U >::TPtr RemoveById ( unsigned int  _id)
The removed element
◆ RemoveByIndex()
BaseStore< T, U >::TPtr RemoveByIndex ( unsigned int  _index)
The removed element
◆ RemoveByName()
BaseStore< T, U >::TPtr RemoveByName ( const std::string &  _name)
The removed element
◆ RemoveConstness()
BaseStore< T, U >::UIter RemoveConstness ( ConstUIter  _iter)
◆ RemoveDerived()
BaseStore< T, U >::UPtr RemoveDerived ( UPtr  _object)
◆ RemoveDerivedById()
BaseStore< T, U >::UPtr RemoveDerivedById ( unsigned int  _id)
◆ RemoveDerivedByIndex()
BaseStore< T, U >::UPtr RemoveDerivedByIndex ( unsigned int  _index)
◆ RemoveDerivedByName()
BaseStore< T, U >::UPtr RemoveDerivedByName ( const std::string &  _name)
◆ RemoveImpl()
BaseStore< T, U >::UPtr RemoveImpl ( UIter  _iter)
◆ Size()
unsigned int Size ( ) const
◆ store
UStore store
