| virtual | ~LidarVisual () |
| | Destructor. More...
| virtual void | ClearPoints ()=0 |
| | Clear the points of the lidar visual. More...
| virtual bool | DisplayNonHitting () const =0 |
| | Get if non-hitting rays will be displayed. More...
| virtual unsigned int | HorizontalRayCount () const =0 |
| | Get number of horizontal rays. More...
| virtual double | MaxHorizontalAngle () const =0 |
| | Get maximum horizontal angle. More...
| virtual double | MaxRange () const =0 |
| | Get maximum range of lidar rays. More...
| virtual double | MaxVerticalAngle () const =0 |
| | Get minimum vertical angle. More...
| virtual double | MinHorizontalAngle () const =0 |
| | Get minimum horizontal angle. More...
| virtual double | MinRange () const =0 |
| | Get minimum range of lidar rays. More...
| virtual double | MinVerticalAngle () const =0 |
| virtual gz::math::Pose3d | Offset () const =0 |
| | Get offset of visual. More...
| virtual unsigned int | PointCount () const =0 |
| | Get number of points in laser data. More...
| virtual std::vector< double > | Points () const =0 |
| | Get the points in laser data. More...
| virtual void | SetDisplayNonHitting (bool _display)=0 |
| | Set if non-hitting rays will be displayed (this does not work for TRIANGLE_STRIPS visual) More...
| virtual void | SetHorizontalRayCount (unsigned int _horizontalRayCount)=0 |
| | Set number of horizontal rays. More...
| virtual void | SetMaxHorizontalAngle (double _maxHorizontalAngle)=0 |
| | Set maximum horizontal angle. More...
| virtual void | SetMaxRange (double _maxRange)=0 |
| | Set maximum range of lidar rays. More...
| virtual void | SetMaxVerticalAngle (double _maxVerticalAngle)=0 |
| | Set maximum vertical angle. More...
| virtual void | SetMinHorizontalAngle (double _minHorizontalAngle)=0 |
| | Set minimum horizontal angle. More...
| virtual void | SetMinRange (double _minRange)=0 |
| | Set minimum range of lidar rays. More...
| virtual void | SetMinVerticalAngle (double _minVerticalAngle)=0 |
| | Set minimum vertical angle. More...
| virtual void | SetOffset (const gz::math::Pose3d _offset)=0 |
| | Set offset of visual. More...
| virtual void | SetPoints (const std::vector< double > &_points)=0 |
| | Set lidar points to be visualised. More...
| virtual void | SetPoints (const std::vector< double > &_points, const std::vector< gz::math::Color > &_colors)=0 |
| virtual void | SetSize (double _size)=0 |
| | Set size of the lidar visualization, e.g. size of rasterized lidar points in pixels. More...
| virtual void | SetType (const LidarVisualType _type)=0 |
| | Set type for lidar visual. More...
| virtual void | SetVerticalRayCount (unsigned int _verticalRayCount)=0 |
| | Set number of vertical rays. More...
| virtual double | Size () const =0 |
| | Get size of the lidar visualization. More...
| virtual LidarVisualType | Type () const =0 |
| | Get the type for lidar visual. More...
| | Update the Visual. More...
| virtual unsigned int | VerticalRayCount () const =0 |
| | Get number of vertical rays. More...
| virtual | ~Visual () |
| | Destructor. More...
| virtual void | AddGeometry (GeometryPtr _geometry)=0 |
| | Add the given geometry to this visual. If the given node is already attached, no work will be done. More...
| virtual void | AddVisibilityFlags (uint32_t _flags)=0 |
| | Add visibility flags. More...
| virtual gz::math::AxisAlignedBox | BoundingBox () const =0 |
| | Get the bounding box in world frame coordinates. More...
| virtual VisualPtr | Clone (const std::string &_name, NodePtr _newParent) const =0 |
| | Clone the visual (and its children) with a new name. More...
| virtual GeometryPtr | GeometryByIndex (unsigned int _index) const =0 |
| | Get geometry at given index. If no geometry exists at given index, NULL will be returned. More...
| virtual unsigned int | GeometryCount () const =0 |
| | Get the number of geometries attached to this visual. More...
| virtual bool | HasGeometry (ConstGeometryPtr _geometry) const =0 |
| | Determine if given geometry is attached to this visual. More...
| virtual gz::math::AxisAlignedBox | LocalBoundingBox () const =0 |
| | Get the local bounding box of the visual. More...
| | Get the material assigned to attached visuals and geometries. More...
| virtual void | RemoveGeometries ()=0 |
| | Remove all attached geometries from this visual. More...
| virtual GeometryPtr | RemoveGeometry (GeometryPtr _geometry)=0 |
| | Remove the given geometry from this visual. If the given node is not a child of this visual, no work will be done. More...
| virtual GeometryPtr | RemoveGeometryByIndex (unsigned int _index)=0 |
| | Remove the geometry at the given index from this visual. If the specified node is not attached this visual, no work will be done. More...
| virtual void | RemoveVisibilityFlags (uint32_t _flags)=0 |
| | Remove visibility flags. More...
| virtual void | SetChildMaterial (MaterialPtr _material, bool _unique=true)=0 |
| | Set the material for all attached visuals only. More...
| virtual void | SetGeometryMaterial (MaterialPtr _material, bool _unique=true)=0 |
| | Set the material for all attached geometries only. More...
| | Set the material for all attached visuals and geometries. The specified material will be retrieved from Scene::Material using the given material name. If no material is registered with the given name, no work will be done. More...
| | Set the material for all attached visuals and geometries. More...
| virtual void | SetVisibilityFlags (uint32_t _flags)=0 |
| | Set visibility flags. More...
| virtual void | SetVisible (bool _visible)=0 |
| | Specify if this visual is visible. More...
| virtual void | SetWireframe (bool _show)=0 |
| | Enable or disable wireframe. More...
| virtual uint32_t | VisibilityFlags () const =0 |
| | Get visibility flags. More...
| virtual bool | Wireframe () const =0 |
| | Get whether wireframe is enabled for this visual. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
