#include <OgreAxisVisual.hh>
virtual ~OgreAxisVisual ()
- Public Member Functions inherited from BaseAxisVisual< OgreVisual >
virtual ~BaseAxisVisual ()
 set true to show the axis heads, false otherwise More...
 set true to show the specified axis head, false otherwise More...
virtual ~AxisVisual ()
virtual ~CompositeVisual ()
virtual ~OgreVisual ()
virtual ~BaseVisual ()
virtual ~OgreNode ()
 OgreAxisVisual ()
- Protected Member Functions inherited from BaseAxisVisual< OgreVisual >
 BaseAxisVisual ()
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
uint32_t visibilityFlags
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreAxisVisual()
OgreAxisVisual ( )
◆ ~OgreAxisVisual()
virtual ~OgreAxisVisual ( )
