JointVisual Class Referenceabstract
Represents a joint visual. More...
#include <JointVisual.hh>
virtual ~JointVisual ()
virtual ArrowVisualPtr ArrowVisual () const =0
virtual gz::math::Vector3d Axis () const =0
 Get axis vector. More...
virtual gz::math::Vector3d ParentAxis () const =0
virtual JointVisualPtr ParentAxisVisual () const =0
virtual void SetAxis (const gz::math::Vector3d &_axis, bool _useParentFrame=false)=0
virtual void SetParentAxis (const gz::math::Vector3d &_axis, const std::string &_parentName, bool _useParentFrame=false)=0
virtual void SetType (const JointVisualType _type)=0
virtual JointVisualType Type () const =0
virtual bool UpdateAxis (const gz::math::Vector3d &_axis, bool _useParentFrame=false)=0
virtual bool UpdateParentAxis (const gz::math::Vector3d &_axis, bool _useParentFrame=false)=0
gz/rendering/JointVisual.hh
◆ ~JointVisual()
virtual ~JointVisual ( )
◆ ArrowVisual()
virtual ArrowVisualPtr ArrowVisual ( ) const
Arrow visual.
Implemented in BaseJointVisual< T >.
◆ Axis()
virtual gz::math::Vector3d Axis ( ) const
Get axis vector.
The axis vector.
◆ ParentAxis()
virtual gz::math::Vector3d ParentAxis ( ) const
The parent axis vector.
◆ ParentAxisVisual()
virtual JointVisualPtr ParentAxisVisual ( ) const
Parent axis visual.
◆ SetAxis()
virtual void SetAxis ( const gz::math::Vector3d &  _axis,
bool  _useParentFrame = false
[in]_axisAxis vector.
[in]_useParentFrameTrue if axis vector is expressed in parent frame.
Implemented in BaseJointVisual< T >, BaseJointVisual< OgreVisual >, and BaseJointVisual< Ogre2Visual >.
◆ SetParentAxis()
virtual void SetParentAxis ( const gz::math::Vector3d &  _axis,
const std::string &  _parentName,
[in]_parentNameJoint parent name.
◆ SetType()
virtual void SetType ( const JointVisualType  _type)
[in]_typeThe type of visualisation for joint.
◆ Type()
virtual JointVisualType Type ( ) const
The joint visual type.
◆ UpdateAxis()
virtual bool UpdateAxis ( const gz::math::Vector3d &  _axis,
True if axis was updated else false.
◆ UpdateParentAxis()
virtual bool UpdateParentAxis ( const gz::math::Vector3d &  _axis,
True if parent axis was updated else false.
