PointLight Class Reference
#include <gz/rendering/Light.hh>
virtual | ~PointLight () |
Destructor. More... | |
virtual | ~Light () |
virtual double | AttenuationConstant () const =0 |
Get the attenuation constant value. More... | |
virtual double | AttenuationLinear () const =0 |
Get the attenuation linear value. More... | |
virtual double | AttenuationQuadratic () const =0 |
Get the attenuation quadratic value. More... | |
virtual double | AttenuationRange () const =0 |
Get the attenuation range. More... | |
virtual bool | CastShadows () const =0 |
Determine if this light cast shadows. More... | |
virtual math::Color | DiffuseColor () const =0 |
Get the diffuse color. More... | |
virtual double | Intensity () const =0 |
Get the light intensity. More... | |
virtual void | SetAttenuationConstant (double _value)=0 |
Set the attenuation constant value. More... | |
virtual void | SetAttenuationLinear (double _value)=0 |
Set the attenuation linear value. More... | |
virtual void | SetAttenuationQuadratic (double _value)=0 |
Set the attenuation quadratic value. More... | |
virtual void | SetAttenuationRange (double _range)=0 |
Set the attenuation range. More... | |
virtual void | SetCastShadows (bool _castShadows)=0 |
Specify if this light should cast shadows. More... | |
virtual void | SetDiffuseColor (const math::Color &_color)=0 |
Set the diffuse color. More... | |
virtual void | SetDiffuseColor (double _r, double _g, double _b, double _a=1.0)=0 |
virtual void | SetIntensity (double _intensity)=0 |
Set the light intensity. More... | |
virtual void | SetSpecularColor (const math::Color &_color)=0 |
Set the specular color. More... | |
virtual void | SetSpecularColor (double _r, double _g, double _b, double _a=1.0)=0 |
virtual math::Color | SpecularColor () const =0 |
Get the specular color. More... | |
virtual | ~Node () |
virtual void | AddChild (NodePtr _child)=0 |
Add the given node to this node. If the given node is already a child, no work will be done. More... | |
virtual NodePtr | ChildById (unsigned int _id) const =0 |
Get node with given ID. If no child exists with given ID, NULL will be returned. More... | |
virtual NodePtr | ChildByIndex (unsigned int _index) const =0 |
Get node at given index. If no child exists at given index, NULL will be returned. More... | |
virtual NodePtr | ChildByName (const std::string &_name) const =0 |
Get node with given name. If no child exists with given name, NULL will be returned. More... | |
virtual unsigned int | ChildCount () const =0 |
Get number of child nodes. More... | |
virtual bool | HasChild (ConstNodePtr _child) const =0 |
Determine if given node is an attached child. More... | |
virtual bool | HasChildId (unsigned int _id) const =0 |
Determine if node with given ID is an attached child. More... | |
virtual bool | HasChildName (const std::string &_name) const =0 |
Determine if node with given name is an attached child. More... | |
virtual bool | HasParent () const =0 |
Determine if this Node is attached to another Node. More... | |
virtual bool | HasUserData (const std::string &_key) const =0 |
Check if node has custom data. More... | |
virtual bool | InheritScale () const =0 |
Determine if this node inherits scale from this parent. More... | |
virtual math::Pose3d | InitialLocalPose () const =0 |
Get the initial local pose. More... | |
virtual math::Pose3d | LocalPose () const =0 |
Get the local pose. More... | |
virtual math::Vector3d | LocalPosition () const =0 |
Get the local position. More... | |
virtual math::Quaterniond | LocalRotation () const =0 |
Get the local rotation. More... | |
virtual math::Vector3d | LocalScale () const =0 |
Get the local scale. More... | |
virtual math::Vector3d | Origin () const =0 |
Get position of origin. More... | |
virtual NodePtr | Parent () const =0 |
Get the parent Node. More... | |
virtual NodePtr | RemoveChild (NodePtr _child)=0 |
Remove (detach) the given node from this node. If the given node is not a child of this node, no work will be done. More... | |
virtual NodePtr | RemoveChildById (unsigned int _id)=0 |
Remove (detach) the node with the given ID from this node. If the specified node is not a child of this node, no work will be done. More... | |
virtual NodePtr | RemoveChildByIndex (unsigned int _index)=0 |
Remove (detach) the node at the given index from this node. If the specified node is not a child of this node, no work will be done. More... | |
virtual NodePtr | RemoveChildByName (const std::string &_name)=0 |
Remove (detach) the node with the given name from this node. If the specified node is not a child of this node, no work will be done. More... | |
virtual void | RemoveChildren ()=0 |
Remove all child nodes from this node This detaches all the child nodes but does not destroy them. More... | |
virtual void | RemoveParent ()=0 |
Detach this Node from its parent. If this Node does not have a parent, no work will be done. More... | |
virtual void | Scale (const math::Vector3d &_scale)=0 |
Scale the current scale by the given scalars. More... | |
virtual void | Scale (double _scale)=0 |
Scale the current scale by the given scalar. The given scalar will be assigned to the x, y, and z coordinates. More... | |
virtual void | Scale (double _x, double _y, double _z)=0 |
virtual void | SetInheritScale (bool _inherit)=0 |
Specify if this node inherits scale from its parent. More... | |
virtual void | SetLocalPose (const math::Pose3d &_pose)=0 |
Set the local pose. More... | |
virtual void | SetLocalPosition (const math::Vector3d &_position)=0 |
Set the local position. More... | |
virtual void | SetLocalPosition (double _x, double _y, double _z)=0 |
virtual void | SetLocalRotation (const math::Quaterniond &_rotation)=0 |
Set the local rotation. More... | |
virtual void | SetLocalRotation (double _r, double _p, double _y)=0 |
virtual void | SetLocalRotation (double _w, double _x, double _y, double _z)=0 |
virtual void | SetLocalScale (const math::Vector3d &_scale)=0 |
Set the local scale. More... | |
virtual void | SetLocalScale (double _scale)=0 |
Set the local scale. The given scale will be assigned to the x, y, and z coordinates. More... | |
virtual void | SetLocalScale (double _x, double _y, double _z)=0 |
virtual void | SetOrigin (const math::Vector3d &_origin)=0 |
Set position of origin. The position should be relative to the original origin of the geometry. More... | |
virtual void | SetOrigin (double _x, double _y, double _z)=0 |
virtual void | SetUserData (const std::string &_key, Variant _value)=0 |
Store any custom data associated with this node. More... | |
virtual void | SetWorldPose (const math::Pose3d &_pose)=0 |
Set the world pose. More... | |
virtual void | SetWorldPosition (const math::Vector3d &_position)=0 |
Set the world position. More... | |
virtual void | SetWorldPosition (double _x, double _y, double _z)=0 |
virtual void | SetWorldRotation (const math::Quaterniond &_rotation)=0 |
Set the world rotation. More... | |
virtual void | SetWorldRotation (double _r, double _p, double _y)=0 |
virtual void | SetWorldRotation (double _w, double _x, double _y, double _z)=0 |
virtual void | SetWorldScale (const math::Vector3d &_scale)=0 |
Set the world scale. More... | |
virtual void | SetWorldScale (double _scale)=0 |
Set the world scale. The given scale will be assigned to the x, y, and z coordinates. More... | |
virtual void | SetWorldScale (double _x, double _y, double _z)=0 |
virtual Variant | UserData (const std::string &_key) const =0 |
Get custom data stored in this node. More... | |
virtual math::Pose3d | WorldPose () const =0 |
Get the world pose. More... | |
virtual math::Vector3d | WorldPosition () const =0 |
Get the world position. More... | |
virtual math::Quaterniond | WorldRotation () const =0 |
Get the world rotation. More... | |
virtual math::Vector3d | WorldScale () const =0 |
Get the world scale. More... | |
virtual math::Pose3d | WorldToLocal (const math::Pose3d &_pose) const =0 |
Convert given world pose to local pose. More... | |
virtual | ~Object () |
virtual void | Destroy ()=0 |
🔗~PointLight()
virtual |
