Projector Class Referenceabstract
A projector that projects a texture onto a surface. More...
#include <Projector.hh>
virtual ~Projector ()
 Get the projector's far clipping plane distance. More...
 Get the projector's horizontal field-of-view. More...
 Get whether the projector is enabled or disabled. More...
 Get the projector's near clipping plane distance. More...
 Set whether the projector is enabled or disabled. More...
virtual void SetFarClipPlane (double _far)=0
 Set the projector's far clipping plane distance. More...
 Set the projector's horizontal field-of-view. More...
virtual void SetNearClipPlane (double _near)=0
 Set the projector's near clipping plane distance. More...
virtual void SetTexture (const std::string &_texture)=0
 Load a texture into the projector. More...
virtual std::string Texture () const =0
 Get the URI of the texture file used by the projector. More...
gz/rendering/Projector.hh
◆ ~Projector()
virtual ~Projector ( )
◆ FarClipPlane()
virtual double FarClipPlane ( ) const
Far clipping plane distance
Implemented in BaseProjector< T >.
◆ HFOV()
virtual math::Angle HFOV ( ) const
Angle containing the projector's horizontal field-of-view
◆ IsEnabled()
true if enabled, false otherwise
◆ NearClipPlane()
virtual double NearClipPlane ( ) const
Near clipping plane distance
◆ SetEnabled()
[in]_enabledTrue to enable the projector.
Implemented in BaseProjector< T >, BaseProjector< OgreVisual >, BaseProjector< Ogre2Visual >, OgreProjector, and Ogre2Projector.
◆ SetFarClipPlane()
virtual void SetFarClipPlane ( double  _far)
Implemented in BaseProjector< T >, BaseProjector< OgreVisual >, and BaseProjector< Ogre2Visual >.
◆ SetHFOV()
◆ SetNearClipPlane()
virtual void SetNearClipPlane ( double  _near)
◆ SetTexture()
virtual void SetTexture ( const std::string &  _texture)
[in]_textureName of the texture to project.
◆ Texture()
