Ogre 2.x implementation of a Projector class. More...
#include <Ogre2Projector.hh>
virtual ~Ogre2Projector ()
 Set whether the projector is enabled or disabled. More...
- Public Member Functions inherited from BaseProjector< Ogre2Visual >
virtual ~BaseProjector ()
 Get the projector's far clipping plane distance. More...
 Get the projector's horizontal field-of-view. More...
bool IsEnabled () const override
 Get whether the projector is enabled or disabled. More...
 Get the projector's near clipping plane distance. More...
virtual void SetFarClipPlane (double _far) override
 Set the projector's far clipping plane distance. More...
 Set the projector's horizontal field-of-view. More...
virtual void SetNearClipPlane (double _near) override
 Set the projector's near clipping plane distance. More...
void SetTexture (const std::string &_texture) override
 Load a texture into the projector. More...
 Get the URI of the texture file used by the projector. More...
- Public Member Functions inherited from Projector
virtual ~Projector ()
virtual std::string Texture () const =0
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Ogre2Projector ()
- Protected Member Functions inherited from BaseProjector< Ogre2Visual >
 BaseProjector ()
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseProjector< Ogre2Visual >
bool enabled
 Indicates whether or not the projector is enabled. More...
double farClip
 Projector's far clip plane. More...
math::Angle hfov
 Projector's horizontal field of view. More...
double nearClip
 Projector's near clip plane. More...
std::string textureName
 Texture used by the projector. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2Projector()
Ogre2Projector ( )
◆ ~Ogre2Projector()
virtual ~Ogre2Projector ( )
Reimplemented from BaseVisual< Ogre2Node >.
◆ SetEnabled()
[in]_enabledTrue to enable the projector.
Implements Projector.
