BaseRenderWindow< T > Class Template Reference
 BaseRenderWindow ()
virtual ~BaseRenderWindow ()
virtual double DevicePixelRatio () const
virtual std::string Handle () const
virtual void OnMove ()
virtual void OnResize (const unsigned int _width, const unsigned int _height)
virtual void SetDevicePixelRatio (const double _ratio)
virtual void SetHandle (const std::string &_handle)
- Public Member Functions inherited from RenderWindow
virtual ~RenderWindow ()
virtual ~RenderTarget ()
std::string handle
double ratio = 1.0
◆ BaseRenderWindow()
◆ ~BaseRenderWindow()
~BaseRenderWindow
◆ DevicePixelRatio()
double DevicePixelRatio ( ) const
Device to pixel ratio
Implements RenderWindow.
◆ Handle()
std::string Handle ( ) const
Window handle
◆ OnMove()
void OnMove ( )
◆ OnResize()
void OnResize ( const unsigned int  _width,
[in]_widthNew window width in pixels
[in]_heightNew window height in pixels
◆ SetDevicePixelRatio()
void SetDevicePixelRatio ( const double  _ratio)
[in]_ratioDevice to pixel ratio
◆ SetHandle()
void SetHandle ( const std::string &  _handle)
[in]_handleWindow handle
◆ handle
std::string handle
◆ ratio
double ratio = 1.0
