Implements Ogre's Run-Time Shader system. More...
#include <rendering/rendering.hh>
Public Types
enum  LightingModel { SSLM_PerVertexLighting, SSLM_PerPixelLighting, SSLM_NormalMapLightingTangentSpace, SSLM_NormalMapLightingObjectSpace }
 The type of lighting. More...
void AddScene (OgreScenePtr _scene)
 Add a scene manager. More...
void ApplyShadows (OgreScenePtr _scene)
 Apply shadows to a scene. More...
void AttachEntity (OgreSubMesh *_vis)
 Set an Ogre::Entity to use RT shaders. More...
void Clear ()
 Clear the shader system. More...
void DetachEntity (OgreSubMesh *_vis)
 Remove and entity. More...
void Fini ()
 Finalize the shader system. More...
void GenerateShaders (OgreSubMesh *_subMesh)
 Generate shaders for an entity. More...
bool Init ()
 Initialize the run time shader system. More...
bool IsInitialized () const
 Get if RTShaderSystem is initialized or not. More...
Ogre::PSSMShadowCameraSetup * PSSMShadowCameraSetup () const
 Get the Ogre PSSM Shadows camera setup. More...
void RemoveScene (const std::string &_scene)
 Remove a scene. More...
void RemoveScene (OgreScenePtr _scene)
void RemoveShaders (OgreSubMesh *_subMesh)
void RemoveShadows (OgreScenePtr _scene)
 Remove shadows from a scene. More...
void SetPerPixelLighting (bool _set)
 Set the lighting model to per pixel or per vertex. More...
bool SetShadowTextureSize (const unsigned int _size)
 Set the shadow texture size. More...
unsigned int ShadowTextureSize () const
 Get the shadow texture size. More...
void Update ()
 Update the RT shaders. The call will only take effect if shadow properties changed, e.g. texture size, or the shaders have been marked dirty by UpdateShaders, e.g. when entities are added. The function reapplies shadows if properties have changed, and iterates through all entities added to RTShaderSystem and regenerates shader programs for each entity if shaders are dirty. This function is currently called by OgreScene::PreRender. More...
void UpdateShaders ()
 Update the shaders. This should not be called frequently. More...
static void AttachViewport (Ogre::Viewport *_viewport, OgreScenePtr _scene)
 Set a viewport to use shaders. More...
static void DetachViewport (Ogre::Viewport *_viewport, OgreScenePtr _scene)
 Set a viewport to not use shaders. More...
static OgreRTShaderSystem * Instance ()
 Get a pointer to the Ogre RT shader system. More...
- Static Public Member Functions inherited from SingletonT< OgreRTShaderSystem >
static T * Instance ()
- Protected Member Functions inherited from SingletonT< OgreRTShaderSystem >
 SingletonT ()
virtual ~SingletonT ()
This class allows Gazebo to generate per-pixel shaders for every material at run-time.
◆ LightingModel
Enumerator
Per-Vertex lighting: best performance.
Per-Pixel lighting: best look.
Normal Map lighting: lighting calculations have been stored in a light map (texture) using tangent space.
Normal Map lighting: lighting calculations have been stored in a light map (texture) using object space.
◆ AddScene()
void AddScene ( OgreScenePtr  _scene)
[in]_sceneThe scene to process
◆ ApplyShadows()
void ApplyShadows ( OgreScenePtr  _scene)
[in]_sceneThe scene to receive shadows.
◆ AttachEntity()
void AttachEntity ( OgreSubMesh *  _vis)
[in]_visOgreSubMesh that will use the OgreRTShaderSystem.
◆ AttachViewport()
static void AttachViewport ( Ogre::Viewport *  _viewport,
OgreScenePtr  _scene
static
[in]_viewportThe viewport to add.
[in]_sceneThe scene that the viewport uses.
◆ Clear()
void Clear ( )
◆ DetachEntity()
void DetachEntity ( OgreSubMesh *  _vis)
Remove and entity.
[in]_visRemove this visual.
◆ DetachViewport()
static void DetachViewport ( Ogre::Viewport *  _viewport,
OgreScenePtr  _scene
static
[in]_viewportThe viewport to remove.
◆ Fini()
void Fini ( )
◆ GenerateShaders()
void GenerateShaders ( OgreSubMesh *  _subMesh)
[in]_subMeshThe submesh to generate shaders for.
bool Init ( )
True if the run time shader system is initialized successfully.
◆ Instance()
static OgreRTShaderSystem* Instance ( )
static
Todo:
(anyone) Remove inheritance from Singleton base class
◆ IsInitialized()
bool IsInitialized ( ) const
True if intialized.
◆ PSSMShadowCameraSetup()
Ogre::PSSMShadowCameraSetup* PSSMShadowCameraSetup ( ) const
The Ogre PSSM Shadows camera setup.
◆ RemoveScene() [1/2]
void RemoveScene ( const std::string &  _scene)
Remove a scene.
[in]_sceneName of the scene to remove.
◆ RemoveScene() [2/2]
void RemoveScene ( OgreScenePtr  _scene)
Remove a scene.
[in]_sceneThe scene to remove
◆ RemoveShaders()
void RemoveShaders ( OgreSubMesh *  _subMesh)
[in]_subMeshThe submesh to remove shaders for.
◆ RemoveShadows()
void RemoveShadows ( OgreScenePtr  _scene)
[in]_sceneThe scene to remove shadows from.
◆ SetPerPixelLighting()
void SetPerPixelLighting ( bool  _set)
[in]_setTrue means to use per-pixel shaders.
◆ SetShadowTextureSize()
bool SetShadowTextureSize ( const unsigned int  _size)
[in]_sizeSize of shadow texture to set to. This must be a power of 2. The default size is 1024.
True if size is set successfully, false otherwise.
◆ ShadowTextureSize()
unsigned int ShadowTextureSize ( ) const
Size of the shadow texture. The default size is 1024.
void Update ( )
◆ UpdateShaders()
void UpdateShaders ( )
