#include <OgreMesh.hh>
| virtual | ~OgreSubMesh () |
| virtual Ogre::SubEntity * | OgreSubEntity () const |
| virtual | ~BaseSubMesh () |
| virtual MaterialPtr | Material () const override |
| | Get the currently assigned material. More...
| virtual void | SetMaterial (const std::string &_name, bool _unique=true) override |
| | Set the materials of this SubMesh. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done. More...
| virtual void | SetMaterial (MaterialPtr _material, bool _unique=true) override |
| | Set the materials of this SubMesh. More...
| virtual | ~SubMesh () |
| | Destructor. More...
| | Destructor. More...
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
◆ OgreSubMesh()
◆ ~OgreSubMesh()
◆ Destroy()
Reimplemented from BaseSubMesh< OgreObject >.
◆ Init()
◆ OgreSubEntity()
| virtual Ogre::SubEntity* OgreSubEntity |
const |
virtual |
◆ SetMaterialImpl()
◆ ogreSubEntity
| Ogre::SubEntity* ogreSubEntity |
protected |
