BaseSubMesh< T > Class Template Referenceabstract
#include <BaseMesh.hh>
virtual ~BaseSubMesh ()
 Get the currently assigned material. More...
 Set the materials of this SubMesh. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done. More...
 Set the materials of this SubMesh. More...
virtual void SetMaterialImpl (MaterialPtr _material)=0
 Engine implementation for setting the material of this SubMesh. More...
- Public Member Functions inherited from SubMesh
virtual ~SubMesh ()
 BaseSubMesh ()
bool ownsMaterial = false
 Flag to indicate whether or not this submesh should be responsible for destroying the material. More...
◆ BaseSubMesh()
BaseSubMesh
◆ ~BaseSubMesh()
~BaseSubMesh
void Destroy ( )
Reimplemented in Ogre2SubMesh, and OgreSubMesh.
The currently assigned material
Implements SubMesh.
void PreRender ( )
◆ SetMaterial() [1/2]
bool  _unique = true
Implements SubMesh.
◆ SetMaterial() [2/2]
bool  _unique = true
Implements SubMesh.
◆ SetMaterialImpl()
virtual void SetMaterialImpl ( MaterialPtr  _material)
Implemented in Ogre2SubMesh, and OgreSubMesh.
◆ material
◆ ownsMaterial
