Ogre2.x implementation of the render window class. More...
#include <Ogre2RenderTarget.hh>
virtual ~Ogre2RenderWindow ()
 Destroy the render target. More...
virtual bool IsRenderWindow () const override
 Returns true if this is a render window. More...
virtual Ogre::TextureGpu * RenderTarget () const override
 Get a pointer to the ogre render target containing the results of the render. More...
- Public Member Functions inherited from BaseRenderWindow< Ogre2RenderTarget >
 BaseRenderWindow ()
virtual ~BaseRenderWindow ()
virtual double DevicePixelRatio () const
virtual std::string Handle () const
virtual void OnMove ()
virtual void OnResize (const unsigned int _width, const unsigned int _height)
virtual void SetDevicePixelRatio (const double _ratio)
virtual void SetHandle (const std::string &_handle)
- Public Member Functions inherited from RenderWindow
virtual ~RenderWindow ()
virtual double DevicePixelRatio () const =0
virtual std::string Handle () const =0
virtual ~RenderTarget ()
- Public Member Functions inherited from Ogre2RenderTarget
virtual ~Ogre2RenderTarget ()
 Get the anti-aliasing level. More...
virtual MaterialPtr BackgroundMaterial () const
 Get the background material of this camera. More...
 Get a pointer to the internal ogre camera. More...
 Copy the render target buffer data to an image. More...
unsigned int GLIdImpl () const
void MetalIdImpl (void *_textureIdPtr) const
virtual void Render ()
 Main render call. More...
 set the anti-aliasing level More...
 Set the background color of the render target. More...
virtual void SetBackgroundMaterial (MaterialPtr _material)
 Set the background material of this camera. More...
 Set the ogre camera to use for this render target. More...
void SetShadowsNodeDefDirty ()
 Set visibility mask for the viewport associated with this render target. More...
virtual uint32_t VisibilityMask () const
 Get visibility mask for the viewport associated with this render target. More...
- Public Member Functions inherited from BaseRenderTarget< Ogre2Object >
 BaseRenderTarget ()
virtual ~BaseRenderTarget ()
virtual void BuildTarget ()
 Build the render window. More...
 Rebuild the render target. More...
- Protected Member Functions inherited from Ogre2RenderTarget
virtual void BuildCompositor ()
 Build the compositor. More...
void BuildTargetImpl ()
 Build the render texture. More...
virtual void DestroyCompositor ()
 Destroy the compositor. More...
void DestroyTargetImpl ()
 Destroy the render texture. More...
virtual void RebuildCompositor ()
 Rebuild the compositor. More...
 Implementation of the Rebuild function. More...
void RebuildMaterial ()
Ogre::TextureGpu * RenderTargetImpl () const
 Get a pointer to the ogre render target containing the results of the render (implemented separately to avoid breaking ABI of the pure virtual function) More...
uint8_t TargetFSAA () const
 Returns the FSAA to use based on supported specs by HW and value specified in Ogre2RenderTarget::AntiAliasing. More...
 Update the background color. More...
virtual void UpdateBackgroundMaterial ()
 Update the background material. More...
 Update the render pass chain. More...
- Protected Member Functions inherited from BaseRenderTarget< Ogre2Object >
virtual void Rebuild ()
virtual void Init ()
Ogre::TextureGpu * ogreRenderWindow = nullptr
 Pointer to the internal ogre render target object. More...
- Protected Attributes inherited from BaseRenderWindow< Ogre2RenderTarget >
std::string handle
double ratio
- Protected Attributes inherited from Ogre2RenderTarget
unsigned int antiAliasing = 4
 Anti-aliasing level. More...
MaterialPtr backgroundMaterial
 Background material of the render target. More...
bool backgroundMaterialDirty = false
 Flag to indicate if the render target background material has changed. More...
bool colorDirty = true
 Flag to indicate if the render target color has changed. More...
Ogre2RenderTargetMaterialPtr materialApplicator
 Stores the background color of the render target. More...
 Pointer to the internal ogre camera. More...
Ogre::CompositorWorkspace * ogreCompositorWorkspace = nullptr
 Ogre's compositor workspace - the main interface to render into a render target or render texture. More...
std::string ogreCompositorWorkspaceDefName
 Ogre's compositor workspace definition name. More...
 visibility mask associated with this render target More...
- Protected Attributes inherited from BaseRenderTarget< Ogre2Object >
PixelFormat format
unsigned int height
bool renderPassDirty
bool targetDirty
unsigned int width
- Static Public Member Functions inherited from Ogre2RenderTarget
static void UpdateRenderPassChain (Ogre::CompositorWorkspace *_workspace, const std::string &_workspaceDefName, const std::string &_baseNode, const std::string &_finalNode, const std::vector< RenderPassPtr > &_renderPasses, bool _recreateNodes, Ogre::TextureGpu *(*_ogreTextures)[2], bool _isRenderWindow)
◆ Ogre2RenderWindow()
Ogre2RenderWindow ( )
◆ ~Ogre2RenderWindow()
virtual ~Ogre2RenderWindow ( )
◆ BuildTarget()
virtual void BuildTarget ( )
Implements Ogre2RenderTarget.
◆ IsRenderWindow()
virtual bool IsRenderWindow ( ) const
True if this render target is a render window
Reimplemented from Ogre2RenderTarget.
◆ RebuildTarget()
◆ RenderTarget()
virtual Ogre::TextureGpu* RenderTarget ( ) const
◆ ogreRenderWindow
Ogre::TextureGpu* ogreRenderWindow = nullptr
