Ogre2.x implementation of the render texture class. More...
#include <Ogre2RenderTarget.hh>
virtual ~Ogre2RenderTexture ()
 Destroy the render target. More...
virtual unsigned int GLId () const override
virtual void MetalId (void *_textureIdPtr) const override
 Gets the Metal texture id. A valid Id is obtained only if this is an Metal render texture. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease. More...
virtual Ogre::TextureGpu * RenderTarget () const override
 Get a pointer to the ogre render target containing the results of the render. More...
- Public Member Functions inherited from BaseRenderTexture< Ogre2RenderTarget >
 BaseRenderTexture ()
virtual ~BaseRenderTexture ()
virtual ~RenderTexture ()
virtual ~RenderTarget ()
- Public Member Functions inherited from Ogre2RenderTarget
virtual ~Ogre2RenderTarget ()
 Get the anti-aliasing level. More...
virtual MaterialPtr BackgroundMaterial () const
 Get the background material of this camera. More...
 Get a pointer to the internal ogre camera. More...
 Copy the render target buffer data to an image. More...
unsigned int GLIdImpl () const
virtual bool IsRenderWindow () const
 Returns true if this is a render window. More...
void MetalIdImpl (void *_textureIdPtr) const
virtual void Render ()
 Main render call. More...
 set the anti-aliasing level More...
 Set the background color of the render target. More...
virtual void SetBackgroundMaterial (MaterialPtr _material)
 Set the background material of this camera. More...
 Set the ogre camera to use for this render target. More...
void SetShadowsNodeDefDirty ()
 Set visibility mask for the viewport associated with this render target. More...
virtual uint32_t VisibilityMask () const
 Get visibility mask for the viewport associated with this render target. More...
- Public Member Functions inherited from BaseRenderTarget< Ogre2Object >
 BaseRenderTarget ()
virtual ~BaseRenderTarget ()
virtual void BuildTarget ()
 Build the render texture. More...
virtual void DestroyTarget ()
 Destroy the render texture. More...
 Rebuild the render target. More...
- Protected Member Functions inherited from Ogre2RenderTarget
virtual void BuildCompositor ()
 Build the compositor. More...
void BuildTargetImpl ()
virtual void DestroyCompositor ()
 Destroy the compositor. More...
void DestroyTargetImpl ()
virtual void RebuildCompositor ()
 Rebuild the compositor. More...
 Implementation of the Rebuild function. More...
void RebuildMaterial ()
Ogre::TextureGpu * RenderTargetImpl () const
 Get a pointer to the ogre render target containing the results of the render (implemented separately to avoid breaking ABI of the pure virtual function) More...
uint8_t TargetFSAA () const
 Returns the FSAA to use based on supported specs by HW and value specified in Ogre2RenderTarget::AntiAliasing. More...
 Update the background color. More...
virtual void UpdateBackgroundMaterial ()
 Update the background material. More...
 Update the render pass chain. More...
- Protected Member Functions inherited from BaseRenderTarget< Ogre2Object >
virtual void Rebuild ()
virtual void Init ()
- Static Public Member Functions inherited from Ogre2RenderTarget
static void UpdateRenderPassChain (Ogre::CompositorWorkspace *_workspace, const std::string &_workspaceDefName, const std::string &_baseNode, const std::string &_finalNode, const std::vector< RenderPassPtr > &_renderPasses, bool _recreateNodes, Ogre::TextureGpu *(*_ogreTextures)[2], bool _isRenderWindow)
- Protected Attributes inherited from Ogre2RenderTarget
unsigned int antiAliasing = 4
 Anti-aliasing level. More...
MaterialPtr backgroundMaterial
 Background material of the render target. More...
bool backgroundMaterialDirty = false
 Flag to indicate if the render target background material has changed. More...
bool colorDirty = true
 Flag to indicate if the render target color has changed. More...
Ogre2RenderTargetMaterialPtr materialApplicator
 Stores the background color of the render target. More...
 Pointer to the internal ogre camera. More...
Ogre::CompositorWorkspace * ogreCompositorWorkspace = nullptr
 Ogre's compositor workspace - the main interface to render into a render target or render texture. More...
std::string ogreCompositorWorkspaceDefName
 Ogre's compositor workspace definition name. More...
 visibility mask associated with this render target More...
- Protected Attributes inherited from BaseRenderTarget< Ogre2Object >
PixelFormat format
unsigned int height
bool renderPassDirty
bool targetDirty
unsigned int width
◆ Ogre2RenderTexture()
Ogre2RenderTexture ( )
◆ ~Ogre2RenderTexture()
virtual ~Ogre2RenderTexture ( )
◆ BuildTarget()
virtual void BuildTarget ( )
Implements Ogre2RenderTarget.
◆ DestroyTarget()
virtual void DestroyTarget ( )
◆ GLId()
virtual unsigned int GLId ( ) const
Implements RenderTexture.
◆ MetalId()
virtual void MetalId ( void *  _textureIdPtr) const
Reimplemented from BaseRenderTexture< Ogre2RenderTarget >.
◆ PostRender()
virtual void PostRender ( )
Reimplemented from Ogre2RenderTarget.
◆ RebuildTarget()
◆ RenderTarget()
virtual Ogre::TextureGpu* RenderTarget ( ) const
