InertiaVisual Class Referenceabstract
Represents a inertia visual. More...
#include <InertiaVisual.hh>
virtual ~InertiaVisual ()
virtual VisualPtr BoxVisual () const =0
 Get the box visual. More...
virtual void Load (const gz::math::Pose3d &_pose, const gz::math::Vector3d &_scale)=0
virtual void SetInertial (const gz::math::Inertiald &_inertial)=0
gz/rendering/InertiaVisual.hh
◆ ~InertiaVisual()
virtual ~InertiaVisual ( )
◆ BoxVisual()
virtual VisualPtr BoxVisual ( ) const
Get the box visual.
Pointer to the box visual
Implemented in OgreInertiaVisual, Ogre2InertiaVisual, and BaseInertiaVisual< T >.
◆ Load()
virtual void Load ( const gz::math::Pose3d &  _pose,
const gz::math::Vector3d &  _scale
Implemented in OgreInertiaVisual, Ogre2InertiaVisual, BaseInertiaVisual< T >, BaseInertiaVisual< OgreVisual >, and BaseInertiaVisual< Ogre2Visual >.
◆ SetInertial()
virtual void SetInertial ( const gz::math::Inertiald &  _inertial)
Implemented in BaseInertiaVisual< T >, BaseInertiaVisual< OgreVisual >, and BaseInertiaVisual< Ogre2Visual >.
