gz/rendering/ogre2/Ogre2Storage.hh
17 #ifndef GZ_RENDERING_OGRE2_OGRE2STORAGE_HH_
18 #define GZ_RENDERING_OGRE2_OGRE2STORAGE_HH_
20 #include <memory>
21
23
31
32 namespace gz
33 {
34  namespace rendering
35  {
36  inline namespace GZ_RENDERING_VERSION_NAMESPACE {
37
38 // armhf failed to build with this code. It can not be removed for the rest
39 // of arches to keep ABI but should be removed in major versions unreleased
40 // see https://github.com/gazebosim/gz-rendering/pull/457
41 #ifndef __ARM_PCS_VFP
42  template class BaseGeometryStore<Ogre2Geometry>;
43  template class BaseLightStore<Ogre2Light>;
44  template class BaseNodeStore<Ogre2Node>;
45  template class BaseSceneStore<Ogre2Scene>;
46  template class BaseSensorStore<Ogre2Sensor>;
47  template class BaseSubMeshStore<Ogre2SubMesh>;
48  template class BaseVisualStore<Ogre2Visual>;
49 #endif
50
51  typedef BaseGeometryStore<Ogre2Geometry> Ogre2GeometryStore;
52  typedef BaseLightStore<Ogre2Light> Ogre2LightStore;
53  typedef BaseNodeStore<Ogre2Node> Ogre2NodeStore;
54  typedef BaseSceneStore<Ogre2Scene> Ogre2SceneStore;
55  typedef BaseSensorStore<Ogre2Sensor> Ogre2SensorStore;
56  typedef BaseSubMeshStore<Ogre2SubMesh> Ogre2SubMeshStore;
57  typedef BaseVisualStore<Ogre2Visual> Ogre2VisualStore;
58
66  }
67  }
68 }
69 #endif
