#include <BaseArrowVisual.hh>
virtual ~BaseArrowVisual ()
virtual ~ArrowVisual ()
virtual ~CompositeVisual ()
 BaseArrowVisual ()
bool rotationVisible = false
 Flag to indicate whether arrow rotation is visible. More...
◆ BaseArrowVisual()
BaseArrowVisual
◆ ~BaseArrowVisual()
~BaseArrowVisual
void Destroy ( )
◆ Head()
VisualPtr Head ( ) const
The arrow-head visual
Implements ArrowVisual.
◆ Rotation()
VisualPtr Rotation ( ) const
The arrow-rotation visual
◆ SetVisible()
Implements Visual.
◆ Shaft()
VisualPtr Shaft ( ) const
The arrow-shaft visual
◆ ShowArrowHead()
void ShowArrowHead ( bool  _b)
[in]_btrue to show the arrow head, false otherwise
◆ ShowArrowRotation()
void ShowArrowRotation ( bool  _b)
[in]_bTrue to show the arrow rotation.
◆ ShowArrowShaft()
void ShowArrowShaft ( bool  _b)
[in]_btrue to show the arrow shaft, false otherwise
◆ rotationVisible
