#include <BaseGrid.hh>
 ~BaseGrid () override
unsigned int CellCount () const override
 Get the number of cells on a planar grid. More...
double CellLength () const override
 Get the cell length. More...
void Destroy () override
void PreRender () override
void SetCellCount (const unsigned int _count) override
 Set the number of cells on a planar grid. More...
void SetCellLength (const double _len) override
 Set the cell length in one direction. The cells are assumed to be square. More...
void SetVerticalCellCount (const unsigned int _count) override
 Set the vertical cell count of the grid. This makes the grid 3D. More...
unsigned int VerticalCellCount () const override
 Get the vertical cell count. More...
virtual ~Grid ()
 Clone the geometry. More...
 BaseGrid ()
unsigned int cellCount = 10u
 Number of cells in grid. More...
double cellLength = 1.0
 Length of a single cell. More...
bool gridDirty = false
 Flag to indicate grid properties have changed. More...
double heightOffset = 0.0
 vertical offset of the XY plane from origin More...
unsigned int verticalCellCount = 0
 Number of cells in vertical direction. More...
template<class T>
class gz::rendering::BaseGrid< T >
◆ BaseGrid()
BaseGrid
◆ ~BaseGrid()
~BaseGrid
◆ CellCount()
unsigned int CellCount ( ) const
Number of cells
Implements Grid.
◆ CellLength()
double CellLength ( ) const
The cell length
Implements Grid.
void Destroy ( )
void PreRender ( )
◆ SetCellCount()
void SetCellCount ( const unsigned int  _count)
[in]_countThe number of cells
Implements Grid.
◆ SetCellLength()
void SetCellLength ( const double  _len)
[in]_lenThe cell length
Implements Grid.
◆ SetVerticalCellCount()
void SetVerticalCellCount ( const unsigned int  _count)
[in]_countNumber of cells in vertical direction.
Implements Grid.
◆ VerticalCellCount()
unsigned int VerticalCellCount ( ) const
The vertical cell count.
Implements Grid.
◆ cellCount
◆ cellLength
◆ gridDirty
◆ heightOffset
◆ verticalCellCount
