Grid Class Referenceabstract
Represents a grid geometry drawn along the XY plane. If vertical cell count is specified then the grid becomes 3D. More...
#include <gz/rendering/Grid>
virtual ~Grid ()
virtual unsigned int CellCount () const =0
 Get the number of cells on a planar grid. More...
virtual double CellLength () const =0
 Get the cell length. More...
virtual void SetCellCount (const unsigned int _count)=0
 Set the number of cells on a planar grid. More...
virtual void SetCellLength (const double _len)=0
 Set the cell length in one direction. The cells are assumed to be square. More...
virtual void SetVerticalCellCount (const unsigned int _count)=0
 Set the vertical cell count of the grid. This makes the grid 3D. More...
virtual unsigned int VerticalCellCount () const =0
 Get the vertical cell count. More...
 Clone the geometry. More...
◆ ~Grid()
virtual ~Grid ( )
◆ CellCount()
virtual unsigned int CellCount ( ) const
Number of cells
Implemented in BaseGrid< T >, BaseGrid< Ogre2Geometry >, and BaseGrid< OgreGeometry >.
◆ CellLength()
virtual double CellLength ( ) const
The cell length
◆ SetCellCount()
virtual void SetCellCount ( const unsigned int  _count)
[in]_countThe number of cells
◆ SetCellLength()
virtual void SetCellLength ( const double  _len)
[in]_lenThe cell length
◆ SetVerticalCellCount()
virtual void SetVerticalCellCount ( const unsigned int  _count)
[in]_countNumber of cells in vertical direction.
◆ VerticalCellCount()
virtual unsigned int VerticalCellCount ( ) const
The vertical cell count.
