Base implementation of a light visual. More...
#include <BaseLightVisual.hh>
virtual ~BaseLightVisual ()
std::vector< gz::math::Vector3d > CreateVisualLines ()
 Get inner angle. More...
 Get outer angle. More...
virtual void SetOuterAngle (double _outerAngle) override
 set type of the light More...
virtual ~LightVisual ()
 Descructor. More...
 BaseLightVisual ()
bool dirtyLightVisual = false
double innerAngle = 0
double outerAngle = 0
LightVisualType type = LightVisualType::LVT_EMPTY
 Type of light visual. More...
template<class T>
class gz::rendering::BaseLightVisual< T >
◆ BaseLightVisual()
BaseLightVisual
◆ ~BaseLightVisual()
~BaseLightVisual
◆ CreateVisualLines()
References vector< T >::emplace_back(), gz::rendering::LVT_DIRECTIONAL, gz::rendering::LVT_POINT, and gz::rendering::LVT_SPOT.
void Init
Reimplemented in Ogre2LightVisual, and OgreLightVisual.
◆ InnerAngle()
double InnerAngle ( )
Get inner angle.
The light inner angle
Implements LightVisual.
◆ OuterAngle()
double OuterAngle ( )
Get outer angle.
The light outer angle
void PreRender ( )
◆ SetInnerAngle()
void SetInnerAngle ( double  _innerAngle)
[in]_innerAngleInner angle
◆ SetOuterAngle()
void SetOuterAngle ( double  _outerAngle)
[in]_outerAngleOuter angle
◆ SetType()
void SetType ( LightVisualType  _type)
[in]_typetype of the light
◆ Type()
LightVisualType Type ( )
The light visual type
◆ dirtyLightVisual
◆ innerAngle
◆ outerAngle
◆ type
