Ogre2.x implementation of the light visual class. More...
#include <Ogre2LightVisual.hh>
virtual ~Ogre2LightVisual ()
void CreateVisual ()
 Create the Light Visual in Ogre2. More...
- Public Member Functions inherited from BaseLightVisual< Ogre2Visual >
virtual ~BaseLightVisual ()
std::vector< gz::math::Vector3d > CreateVisualLines ()
 Get inner angle. More...
 Get outer angle. More...
virtual void SetOuterAngle (double _outerAngle) override
 set type of the light More...
virtual ~LightVisual ()
 Descructor. More...
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Ogre2LightVisual ()
- Protected Member Functions inherited from BaseLightVisual< Ogre2Visual >
 BaseLightVisual ()
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseLightVisual< Ogre2Visual >
bool dirtyLightVisual
double innerAngle
double outerAngle
LightVisualType type
 Type of light visual. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2LightVisual()
Ogre2LightVisual ( )
◆ ~Ogre2LightVisual()
virtual ~Ogre2LightVisual ( )
◆ CreateVisual()
void CreateVisual ( )
Reimplemented from BaseLightVisual< Ogre2Visual >.
Implements Visual.
◆ OgreObject()
◆ SetMaterial()
bool  _unique
Implements Visual.
◆ SetMaterialImpl()
[in]_materialOgre material.
