Ogre2.x implementation of the visual class. More...
#include <Ogre2Visual.hh>
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2Visual()
Ogre2Visual ( )
◆ ~Ogre2Visual()
virtual ~Ogre2Visual ( )
◆ AttachGeometry()
◆ BoundingBox()
virtual gz::math::AxisAlignedBox BoundingBox ( ) const
The axis aligned bounding box
Reimplemented from BaseVisual< Ogre2Node >.
◆ DetachGeometry()
◆ Geometries()
◆ LocalBoundingBox()
virtual gz::math::AxisAlignedBox LocalBoundingBox ( ) const
The local bounding box
◆ SetStatic()
virtual void SetStatic ( bool  _static)
Remarks
Performance impact of switching staticness depends on on engine. In ogre2 it isn't expensive but it isn't free either. Try to minimize transitions. Raytracing engines may rely on this information for their BVH structures TODO(anyone): Staticness should be ideally be supplied during construction for maximum performance
ogre2 specific: OgreNext keeps 2 lists of objects. Dynamic and Static. Every frame OgreNext iterates through all nodes & items in the dynamic lists and forcefully updates them (regardless of whether they have actually changed). This may sound slow but Ogre 1.x worked by only updating those objects that have changed, and it was slower. CPUs care a lot more about processing in bulk and having all the data hot in cache.
For the static list, it only iterates through the entire list in that frame when the whole list is tagged as dirty. If one element changes, then the whole list is dirty (OgreNext might be able to optimize it and only update a part of the list by narrowing).
Changing a static node transform implies calling OgreNext's notifyStaticDirty. This is very cheap so it can be called whenever a static object changes. The only thing that needs to be taken into account is that notifyStaticDirty should be called as little as possible. And by "as little as possible" that means ideally it should not be called ever except when loading a scene or when something relevant changed. If it gets called e.g. once per frame or more then it's the same as having all objects dynamic.
Thus if an object is static, make sure you don't keep moving around because it negates the performance of all static objects.
Remarks
(INTERNAL) For implementations: Dynamic Scene Node + Dynamic MovableObject = Valid Static Scene Node + Static MovableObject = Valid Static Scene Node + Dynamic MovableObject = Valid, but rarely makes sense Dynamic Scene Node + Static MovableObject = Invalid
[in]_staticTrue if this visual should be made static
◆ SetVisibilityFlags()
[in]_flagsVisibility flags
◆ SetVisible()
Reimplemented in Ogre2LidarVisual, BaseJointVisual< Ogre2Visual >, BaseAxisVisual< Ogre2Visual >, and BaseArrowVisual< Ogre2Visual >.
◆ SetWireframe()
◆ Static()
virtual bool Static ( ) const
True if the visual is static, false otherwise
SetStatic
◆ Wireframe()
◆ geometries
