#include <Ogre2ParticleEmitter.hh>
virtual ~Ogre2ParticleEmitter ()
void Destroy () override
virtual void SetColorRange (const gz::math::Color &_colorStart, const gz::math::Color &_colorEnd) override
 Sets a color for all particle emitted. The actual color will be interpolated between these two colors Color::White is the default color for the particles unless a specific function is used. Note that this function overrides the particle colors set with SetColorRangeImage(). More...
virtual void SetColorRangeImage (const std::string &_image) override
 Set the path to the color image used as an affector. This affector modifies the color of particles in flight. The colors are taken from a specified image file. The range of color values begins from the left side of the image and move to the right over the lifetime of the particle, therefore only the horizontal dimension of the image is used. Note that this function overrides the particle colors set with SetColorRange(). More...
virtual void SetDuration (double _duration) override
 Set the number of seconds the emitter is active. A value of 0 means infinite duration. Default value is 0. More...
virtual void SetEmitterSize (const gz::math::Vector3d &_size) override
 Set the size of the emitter where the particles are sampled. Default value is (1, 1, 1). Note that the interpretation of the emitter area varies depending on the emmiter type: More...
virtual void SetEmitting (bool _enable) override
 This is used to turn on or off particle emission. Default value is false. More...
virtual void SetLifetime (double _lifetime) override
 Set the number of seconds each particle will ’live’ for before being destroyed. Default value is 5. More...
 Sets the material which all particles in the emitter will use. More...
virtual void SetParticleSize (const gz::math::Vector3d &_size) override
 Set the particle dimensions (width, height, depth). Default value is {1, 1, 1}. More...
virtual void SetRate (double _rate) override
 Set how many particles per second should be emitted. Default value is 10. More...
virtual void SetScaleRate (double _scaleRate) override
 Set the amount by which to scale the particles in both x and y direction per second. More...
virtual void SetType (const EmitterType _type) override
 Set the emitter type. Default value is EM_POINT. More...
virtual void SetVelocityRange (double _minVelocity, double _maxVelocity) override
 Set a velocity range and each particle is emitted with a random velocity within this range (m/s). Default value is 1 for both velocities. More...
- Public Member Functions inherited from BaseParticleEmitter< Ogre2Visual >
virtual ~BaseParticleEmitter ()
virtual gz::math::Color ColorEnd () const override
 Get the end color of the particles. More...
virtual std::string ColorRangeImage () const override
 Get the path to the color image used as an affector. More...
virtual gz::math::Color ColorStart () const override
 Get the starting color of the particles. More...
virtual double Duration () const override
 Get the number of seconds the emitter is active. A value of 0 means infinite duration. More...
virtual gz::math::Vector3d EmitterSize () const override
 Get the size of the emitter where the particles are sampled. More...
virtual bool Emitting () const override
 Is the particle emitter enabled? More...
virtual double Lifetime () const override
 Get the number of seconds each particle will ’live’ for before being destroyed. More...
 Get the material which all particles in the emitter will use. More...
virtual double MaxVelocity () const override
 Get the maximum velocity each particle is emitted (m/s). More...
virtual double MinVelocity () const override
 Get the minimum velocity each particle is emitted (m/s). More...
virtual float ParticleScatterRatio () const override
 Get the particle scatter ratio. More...
virtual gz::math::Vector3d ParticleSize () const override
 Get the particle dimensions (width, height, depth). More...
virtual double Rate () const override
 Get how many particles per second should be emitted. More...
 Reset the particle emitter visual state. More...
virtual double ScaleRate () const override
 Get the amount by which to scale the particles in both x and y direction per second. Default value is 1. More...
virtual void SetParticleScatterRatio (float _ratio) override
 Set the particle scatter ratio. More...
virtual EmitterType Type () const override
 Get the emitter type. More...
- Public Member Functions inherited from ParticleEmitter
virtual ~ParticleEmitter ()
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
Static Public Attributes
static const uint32_t kParticleVisibilityFlags
 Particle system visibility flags. More...
- Protected Member Functions inherited from BaseParticleEmitter< Ogre2Visual >
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseParticleEmitter< Ogre2Visual >
gz::math::Color colorEnd
 The end color of a particle to choose from. More...
std::string colorRangeImage
 The color image. More...
gz::math::Color colorStart
 The start color of a particle to choose from. More...
double duration
 Duration of the emitter. More...
gz::math::Vector3d emitterSize
 Emitter size. More...
bool emitting
 Whether particle emitter is enabled or not. More...
double lifetime
 Particle lifetime. More...
 Particle material. More...
double maxVelocity
 The maximum velocity of each particle. More...
double minVelocity
 The minimum velocity of each particle. More...
float particleScatterRatio
 The particle scatter ratio. This is used to determine the ratio of particles that will be detected by sensors. Increasing the ratio increases the scatter of the particles, which means there is a higher chance of particles reflecting and interfering with depth sensing, making the emitter appear more dense. Decreasing the ratio decreases the scatter of the particles, making it appear less dense. This value should be > 0. More...
gz::math::Vector3d particleSize
 Particle size. More...
double rate
 Rate of emission. More...
double scaleRate
 The scale rate. More...
EmitterType type
 Emitter type. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2ParticleEmitter()
Ogre2ParticleEmitter ( )
◆ ~Ogre2ParticleEmitter()
virtual ~Ogre2ParticleEmitter ( )
void Destroy ( )
Reimplemented from BaseVisual< Ogre2Node >.
Reimplemented from BaseParticleEmitter< Ogre2Visual >.
◆ SetColorRange()
virtual void SetColorRange ( const gz::math::Color &  _colorStart,
const gz::math::Color &  _colorEnd
[in]_colorStartStart color.
[in]_colorEndEnd color.
ColorStart
ColorEnd
◆ SetColorRangeImage()
virtual void SetColorRangeImage ( const std::string &  _image)
[in]_imageThe color image name.
ColorRangeImage
◆ SetDuration()
virtual void SetDuration ( double  _duration)
[in]_durationTotal duration of the emitter (seconds).
Duration
◆ SetEmitterSize()
virtual void SetEmitterSize ( const gz::math::Vector3d &  _size)
  • EM_POINT: The area is ignored.
  • EM_BOX: The area is interpreted as width X height X depth.
  • EM_CYLINDER: The area is interpreted as the bounding box of the cylinder. The cylinder is oriented along the Z-axis.
  • EM_ELLIPSOID: The area is interpreted as the bounding box of an ellipsoid shaped area, i.e. a sphere or squashed-sphere area. The parameters are again identical to EM_BOX, except that the dimensions describe the widest points along each of the axes.
    [in]_sizeSize of the emitter (width, height, depth).
    EmitterSize
◆ SetEmitting()
virtual void SetEmitting ( bool  _enable)
[in]_enableTrue for enabling the emission or false otherwise.
Emitting
◆ SetLifetime()
virtual void SetLifetime ( double  _lifetime)
[in]_lifetimeLifetime of each particle (seconds).
Lifetime
◆ SetMaterial()
[in]_materialThe material pointer.
Material
◆ SetParticleSize()
virtual void SetParticleSize ( const gz::math::Vector3d &  _size)
[in]_sizeParticle dimensions.
ParticleSize
◆ SetRate()
virtual void SetRate ( double  _rate)
[in]_rateParticles per second.
Rate
◆ SetScaleRate()
virtual void SetScaleRate ( double  _scaleRate)
[in]_scaleRateThe scale rate.
ScaleRate
◆ SetType()
virtual void SetType ( const EmitterType  _type)
[in]_typeEmitter type.
EmitterType.
Type.
◆ SetVelocityRange()
virtual void SetVelocityRange ( double  _minVelocity,
double  _maxVelocity
[in]_minVelocityMinimum velocity.
[in]_maxVelocityMaximum velocity.
MinVelocity
MaxVelocity
◆ kParticleVisibilityFlags
static
