BaseParticleEmitter< T > Class Template Reference
A base implementation of the ParticleEmitter class. More...
#include <BaseParticleEmitter.hh>
virtual ~BaseParticleEmitter ()
virtual gz::math::Color ColorEnd () const override
 Get the end color of the particles. More...
virtual std::string ColorRangeImage () const override
 Get the path to the color image used as an affector. More...
virtual gz::math::Color ColorStart () const override
 Get the starting color of the particles. More...
virtual double Duration () const override
 Get the number of seconds the emitter is active. A value of 0 means infinite duration. More...
virtual gz::math::Vector3d EmitterSize () const override
 Get the size of the emitter where the particles are sampled. More...
virtual bool Emitting () const override
 Is the particle emitter enabled? More...
virtual double Lifetime () const override
 Get the number of seconds each particle will ’live’ for before being destroyed. More...
 Get the material which all particles in the emitter will use. More...
virtual double MaxVelocity () const override
 Get the maximum velocity each particle is emitted (m/s). More...
virtual double MinVelocity () const override
 Get the minimum velocity each particle is emitted (m/s). More...
virtual float ParticleScatterRatio () const override
 Get the particle scatter ratio. More...
virtual gz::math::Vector3d ParticleSize () const override
 Get the particle dimensions (width, height, depth). More...
virtual double Rate () const override
 Get how many particles per second should be emitted. More...
 Reset the particle emitter visual state. More...
virtual double ScaleRate () const override
 Get the amount by which to scale the particles in both x and y direction per second. Default value is 1. More...
virtual void SetColorRange (const gz::math::Color &_colorStart, const gz::math::Color &_colorEnd) override
 Sets a color for all particle emitted. The actual color will be interpolated between these two colors Color::White is the default color for the particles unless a specific function is used. Note that this function overrides the particle colors set with SetColorRangeImage(). More...
virtual void SetColorRangeImage (const std::string &_image) override
 Set the path to the color image used as an affector. This affector modifies the color of particles in flight. The colors are taken from a specified image file. The range of color values begins from the left side of the image and move to the right over the lifetime of the particle, therefore only the horizontal dimension of the image is used. Note that this function overrides the particle colors set with SetColorRange(). More...
virtual void SetDuration (double _duration) override
 Set the number of seconds the emitter is active. A value of 0 means infinite duration. Default value is 0. More...
virtual void SetEmitterSize (const gz::math::Vector3d &_size) override
 Set the size of the emitter where the particles are sampled. Default value is (1, 1, 1). Note that the interpretation of the emitter area varies depending on the emmiter type: More...
virtual void SetEmitting (bool _enable) override
 This is used to turn on or off particle emission. Default value is false. More...
virtual void SetLifetime (double _lifetime) override
 Set the number of seconds each particle will ’live’ for before being destroyed. Default value is 5. More...
 Sets the material which all particles in the emitter will use. More...
virtual void SetParticleScatterRatio (float _ratio) override
 Set the particle scatter ratio. More...
virtual void SetParticleSize (const gz::math::Vector3d &_size) override
 Set the particle dimensions (width, height, depth). Default value is {1, 1, 1}. More...
virtual void SetRate (double _rate) override
 Set how many particles per second should be emitted. Default value is 10. More...
virtual void SetScaleRate (double _scaleRate) override
 Set the amount by which to scale the particles in both x and y direction per second. More...
virtual void SetType (const EmitterType _type) override
 Set the emitter type. Default value is EM_POINT. More...
virtual void SetVelocityRange (double _minVelocity, double _maxVelocity) override
 Set a velocity range and each particle is emitted with a random velocity within this range (m/s). Default value is 1 for both velocities. More...
virtual EmitterType Type () const override
 Get the emitter type. More...
- Public Member Functions inherited from ParticleEmitter
virtual ~ParticleEmitter ()
gz::math::Color colorEnd
 The end color of a particle to choose from. More...
std::string colorRangeImage = ""
 The color image. More...
gz::math::Color colorStart
 The start color of a particle to choose from. More...
double duration = 0
 Duration of the emitter. More...
gz::math::Vector3d emitterSize
 Emitter size. More...
bool emitting = false
 Whether particle emitter is enabled or not. More...
double lifetime = 5
 Particle lifetime. More...
MaterialPtr material = nullptr
 Particle material. More...
double maxVelocity = 1
 The maximum velocity of each particle. More...
double minVelocity = 1
 The minimum velocity of each particle. More...
float particleScatterRatio = 0.65f
 The particle scatter ratio. This is used to determine the ratio of particles that will be detected by sensors. Increasing the ratio increases the scatter of the particles, which means there is a higher chance of particles reflecting and interfering with depth sensing, making the emitter appear more dense. Decreasing the ratio decreases the scatter of the particles, making it appear less dense. This value should be > 0. More...
gz::math::Vector3d particleSize = {1, 1, 1}
 Particle size. More...
double rate = 10
 Rate of emission. More...
double scaleRate = 1
 The scale rate. More...
EmitterType type = EM_POINT
 Emitter type. More...
template<class T>
class gz::rendering::BaseParticleEmitter< T >
◆ BaseParticleEmitter()
◆ ~BaseParticleEmitter()
◆ ColorEnd()
gz::math::Color ColorEnd ( ) const
End color.
ColorStart
SetColorRange
Implements ParticleEmitter.
◆ ColorRangeImage()
std::string ColorRangeImage ( ) const
The color image name or empty string if the image is not set.
SetColorRangeImage
◆ ColorStart()
gz::math::Color ColorStart ( ) const
Start color.
ColorEnd
SetColorRange
◆ Duration()
double Duration ( ) const
Total duration of the emitter (seconds).
SetDuration
◆ EmitterSize()
gz::math::Vector3d EmitterSize ( ) const
The emitter size. See SetEmitterSize() for the interpretation of the dimensions depending on the emitter type.
SetEmitterSize
◆ Emitting()
bool Emitting ( ) const
True when enabled or false otherwise.
SetEmitting
void Init
Reimplemented in Ogre2ParticleEmitter.
◆ Lifetime()
double Lifetime ( ) const
Lifetime of each particle (seconds).
SetLifetime
The material pointer.
SetMaterial
◆ MaxVelocity()
double MaxVelocity ( ) const
Maximum velocity.
MinVelocity
SetVelocityRange
◆ MinVelocity()
double MinVelocity ( ) const
Minimum velocity.
MaxVelocity
SetVelocityRange
◆ ParticleScatterRatio()
float ParticleScatterRatio ( ) const
◆ ParticleSize()
gz::math::Vector3d ParticleSize ( ) const
Particle dimensions.
SetParticleSize
void PreRender ( )
◆ Rate()
double Rate ( ) const
Particles per second.
SetRate
◆ Reset()
void Reset
◆ ScaleRate()
double ScaleRate ( ) const
The scale rate.
SetScaleRate
◆ SetColorRange()
void SetColorRange ( const gz::math::Color &  _colorStart,
const gz::math::Color &  _colorEnd
[in]_colorStartStart color.
[in]_colorEndEnd color.
ColorStart
ColorEnd
◆ SetColorRangeImage()
void SetColorRangeImage ( const std::string &  _image)
[in]_imageThe color image name.
ColorRangeImage
◆ SetDuration()
void SetDuration ( double  _duration)
[in]_durationTotal duration of the emitter (seconds).
Duration
◆ SetEmitterSize()
void SetEmitterSize ( const gz::math::Vector3d &  _size)
  • EM_POINT: The area is ignored.
  • EM_BOX: The area is interpreted as width X height X depth.
  • EM_CYLINDER: The area is interpreted as the bounding box of the cylinder. The cylinder is oriented along the Z-axis.
  • EM_ELLIPSOID: The area is interpreted as the bounding box of an ellipsoid shaped area, i.e. a sphere or squashed-sphere area. The parameters are again identical to EM_BOX, except that the dimensions describe the widest points along each of the axes.
    [in]_sizeSize of the emitter (width, height, depth).
    EmitterSize
◆ SetEmitting()
void SetEmitting ( bool  _enable)
[in]_enableTrue for enabling the emission or false otherwise.
Emitting
◆ SetLifetime()
void SetLifetime ( double  _lifetime)
[in]_lifetimeLifetime of each particle (seconds).
Lifetime
◆ SetMaterial()
void SetMaterial ( const MaterialPtr &  _material)
[in]_materialThe material pointer.
Material
◆ SetParticleScatterRatio()
void SetParticleScatterRatio ( float  _ratio)
[in]_ratioThe scatter ratio. The particle emitter's scatter ratio will only be set to _ratio if _ratio > 0.
◆ SetParticleSize()
void SetParticleSize ( const gz::math::Vector3d &  _size)
[in]_sizeParticle dimensions.
ParticleSize
◆ SetRate()
void SetRate ( double  _rate)
[in]_rateParticles per second.
Rate
◆ SetScaleRate()
void SetScaleRate ( double  _scaleRate)
[in]_scaleRateThe scale rate.
ScaleRate
◆ SetType()
void SetType ( const EmitterType  _type)
[in]_typeEmitter type.
EmitterType.
Type.
◆ SetVelocityRange()
void SetVelocityRange ( double  _minVelocity,
double  _maxVelocity
[in]_minVelocityMinimum velocity.
[in]_maxVelocityMaximum velocity.
MinVelocity
MaxVelocity
◆ Type()
EmitterType Type ( ) const
Emitter type.
EmitterType.
SetType.
◆ colorEnd
Initial value:
◆ colorRangeImage
The color image.
◆ colorStart
Initial value:
◆ duration
double duration = 0
◆ emitterSize
Initial value:
Emitter size.
◆ emitting
◆ lifetime
double lifetime = 5
Particle lifetime.
◆ material
Particle material.
◆ maxVelocity
◆ minVelocity
◆ particleScatterRatio
◆ particleSize
Particle size.
◆ rate
double rate = 10
Rate of emission.
◆ scaleRate
The scale rate.
◆ type
Emitter type.
