#include <BaseNativeWindow.hh>
virtual ~BaseNativeWindow ()
virtual void Draw (CameraPtr) override
 A native window is not associated with anything. Calling this function will draw whatever is currently the given camera. More...
virtual void NotifyFocused (bool) override
 Tells the native window whether it's under focus. More...
virtual void NotifyVisible (bool) override
 Tells the native window whether it's visible. More...
virtual void NotifyWindowMovedOrResized () override
 Call this when window resolution has changed. More...
virtual void RequestResolution (uint32_t, uint32_t) override
 Requests a particular resolution. It may not be possible to satisfy it though and the new resolution may be different from current and requested (e.g. if you request 1920x1080 when that's the max monitor resolution after evaluating window borders, the title, and the start menu the OS may shrink the window so the whole thing is visible) More...
- Public Member Functions inherited from NativeWindow
 NativeWindow ()
virtual ~NativeWindow ()
 BaseNativeWindow ()
◆ BaseNativeWindow()
BaseNativeWindow ( )
◆ ~BaseNativeWindow()
virtual ~BaseNativeWindow ( )
◆ Draw()
virtual void Draw ( CameraPtr  _camera)
inlineoverridevirtual
Remarks
Assumes _camera->Render() has already been called If the camera resolution doesn't match, the contents will be stretched.
[in]_cameraCamera to draw
Implements NativeWindow.
Reimplemented in Ogre2NativeWindow.
◆ NotifyFocused()
virtual void NotifyFocused ( bool  _focused)
[in]_focusedTrue if we acquired focus. False if we lost it
◆ NotifyVisible()
virtual void NotifyVisible ( bool  _visible)
[in]_visibleTrue if we are at least partially visible. False otherwise
◆ NotifyWindowMovedOrResized()
virtual void NotifyWindowMovedOrResized ( )
◆ RequestResolution()
virtual void RequestResolution ( uint32_t  _width,
uint32_t  _height
[in]_widthNew width of the window being requested
[in]_heightNew height of the window being requested
