NativeWindow Class Referenceabstract
An abstract interface to a basic native window render-engine. More...
#include <gz/rendering/NativeWindow.hh>
 NativeWindow ()
virtual ~NativeWindow ()
virtual void Draw (CameraPtr _camera)=0
 A native window is not associated with anything. Calling this function will draw whatever is currently the given camera. More...
virtual void NotifyFocused (bool _focused)=0
 Tells the native window whether it's under focus. More...
virtual void NotifyVisible (bool _visible)=0
 Tells the native window whether it's visible. More...
virtual void NotifyWindowMovedOrResized ()=0
 Call this when window resolution has changed. More...
virtual void RequestResolution (uint32_t _width, uint32_t _height)=0
 Requests a particular resolution. It may not be possible to satisfy it though and the new resolution may be different from current and requested (e.g. if you request 1920x1080 when that's the max monitor resolution after evaluating window borders, the title, and the start menu the OS may shrink the window so the whole thing is visible) More...
Note: This is useful when you need a basic single window with both great performance and compatibility. But e.g. creating more than one window may have additional complexities depending on OS and RenderSystem
◆ NativeWindow()
◆ ~NativeWindow()
virtual ~NativeWindow ( )
◆ Draw()
virtual void Draw ( CameraPtr  _camera)
Remarks
Assumes _camera->Render() has already been called If the camera resolution doesn't match, the contents will be stretched.
[in]_cameraCamera to draw
Implemented in BaseNativeWindow, and Ogre2NativeWindow.
◆ NotifyFocused()
virtual void NotifyFocused ( bool  _focused)
[in]_focusedTrue if we acquired focus. False if we lost it
◆ NotifyVisible()
virtual void NotifyVisible ( bool  _visible)
[in]_visibleTrue if we are at least partially visible. False otherwise
◆ NotifyWindowMovedOrResized()
virtual void NotifyWindowMovedOrResized ( )
Implemented in Ogre2NativeWindow, and BaseNativeWindow.
◆ RequestResolution()
virtual void RequestResolution ( uint32_t  _width,
uint32_t  _height
[in]_widthNew width of the window being requested
[in]_heightNew height of the window being requested
