COMVisual Class Referenceabstract
Represents a center of mass visual. More...
#include <COMVisual.hh>
virtual ~COMVisual ()
virtual gz::math::Pose3d InertiaPose () const =0
 Get the inertia pose. More...
virtual double Mass () const =0
 Get the mass of the parent. More...
virtual void SetInertial (const gz::math::Inertiald &_inertial)=0
virtual void SetMass (double _mass)=0
 Set the mass of the parent. More...
virtual VisualPtr SphereVisual () const =0
 Get the sphere visual. More...
gz/rendering/COMVisual.hh
◆ ~COMVisual()
virtual ~COMVisual ( )
◆ InertiaPose()
virtual gz::math::Pose3d InertiaPose ( ) const
Inertia pose in parent frame.
Implemented in BaseCOMVisual< T >, BaseCOMVisual< OgreVisual >, and BaseCOMVisual< Ogre2Visual >.
◆ Mass()
virtual double Mass ( ) const
Parent mass
◆ SetInertial()
virtual void SetInertial ( const gz::math::Inertiald &  _inertial)
◆ SetMass()
virtual void SetMass ( double  _mass)
[in]_massParent mass
◆ SphereVisual()
Pointer to the sphere visual
Implemented in Ogre2COMVisual, OgreCOMVisual, BaseCOMVisual< T >, BaseCOMVisual< OgreVisual >, and BaseCOMVisual< Ogre2Visual >.
