DistortionPass Class Referenceabstract
A render pass that applies distortion to the render target. More...
#include <DistortionPass.hh>
 DistortionPass ()
virtual ~DistortionPass ()
virtual math::Vector2d Center () const =0
 Get the distortion center. More...
virtual double K1 () const =0
 Get the radial distortion coefficient k1. More...
virtual double K2 () const =0
 Get the radial distortion coefficient k2. More...
virtual double K3 () const =0
 Get the radial distortion coefficient k3. More...
virtual double P1 () const =0
 Get the tangential distortion coefficient p1. More...
virtual double P2 () const =0
 Get the tangential distortion coefficient p2. More...
virtual void SetCenter (const math::Vector2d &_center)=0
 Set the distortion center. More...
virtual void SetK1 (double _k1)=0
 Set the radial distortion coefficient k1. More...
virtual void SetK2 (double _k2)=0
 Set the radial distortion coefficient k2. More...
virtual void SetK3 (double _k3)=0
 Set the radial distortion coefficient k3. More...
virtual void SetP1 (double _p1)=0
 Set the tangential distortion coefficient p1. More...
virtual void SetP2 (double _p2)=0
 Set the tangential distortion coefficient p2. More...
virtual ~RenderPass ()
virtual void SetWideAngleCameraAfterStitching (bool _afterStitching)=0
virtual bool WideAngleCameraAfterStitching () const =0
◆ DistortionPass()
◆ ~DistortionPass()
virtual ~DistortionPass ( )
◆ Center()
virtual math::Vector2d Center ( ) const
Distortion center.
Implemented in BaseDistortionPass< T >, and BaseDistortionPass< OgreRenderPass >.
◆ K1()
virtual double K1 ( ) const
Distortion coefficient k1.
◆ K2()
virtual double K2 ( ) const
Distortion coefficient k2.
◆ K3()
virtual double K3 ( ) const
Distortion coefficient k3.
◆ P1()
virtual double P1 ( ) const
Distortion coefficient p1.
◆ P2()
virtual double P2 ( ) const
Distortion coefficient p2.
◆ SetCenter()
virtual void SetCenter ( const math::Vector2d &  _center)
[in]_centerDistortion center.
◆ SetK1()
virtual void SetK1 ( double  _k1)
[in]_k1Distortion coefficient k1.
◆ SetK2()
virtual void SetK2 ( double  _k2)
[in]_k2Distortion coefficient k1.
◆ SetK3()
virtual void SetK3 ( double  _k3)
[in]_k3Distortion coefficient k1.
◆ SetP1()
virtual void SetP1 ( double  _p1)
[in]_p1Distortion coefficient k1.
◆ SetP2()
virtual void SetP2 ( double  _p2)
[in]_p2Distortion coefficient k1.
