Wide angle camera class. More...
#include <WideAngleCamera.hh>
| virtual | ~WideAngleCamera () |
| Destructor. More... | |
| virtual common::ConnectionPtr | ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0 |
| virtual const CameraLens & | Lens () const =0 |
| Get the camera lens used by this wide angle camera. More... | |
| virtual math::Vector3d | Project3d (const math::Vector3d &_pt) const =0 |
| Project 3D world coordinates to screen coordinates. More... | |
| virtual void | SetLens (const CameraLens &_lens)=0 |
| Set the camera lens to use for this wide angle camera. More... | |
| virtual | ~Camera () |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| Writes the last rendered image into a caller owned buffer, for example a message payload, without an intermediate copy. Like Copy, this can be called any number of times after PostRender. The buffer must match the camera's image size and be at least _buffer.MemorySize() bytes. Nothing keeps a pointer to the buffer once this call returns. More... | |
| Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More... | |
| virtual void | PrepareForExternalSampling ()=0 |
| Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More... | |
| virtual void | RemoveAllRenderPasses ()=0 |
| Remove all render passes from the camera. More... | |
| virtual void | RenderTextureMetalId (void *_textureIdPtr) const =0 |
| Get the Metal texture id associated with the render texture used by this camera. A valid Id is obtained only if the underlying render engine is Metal based. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease. More... | |
| virtual void | SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0 |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
◆ ~WideAngleCamera()
virtual |
◆ ConnectNewWideAngleFrame()
pure virtual |
[in] _subscriber New camera listener callback
Implemented in Ogre2WideAngleCamera, OgreWideAngleCamera, BaseWideAngleCamera< T >, BaseWideAngleCamera< Ogre2Sensor >, and BaseWideAngleCamera< OgreSensor >.
◆ Lens()
pure virtual |
- Returns
- Camera lens set to this wide angle camera
Implemented in BaseWideAngleCamera< T >, BaseWideAngleCamera< Ogre2Sensor >, and BaseWideAngleCamera< OgreSensor >.
◆ Project3d()
pure virtual |
[in] _pt 3D world coordinates
- Returns
- Screen coordinates. Z is the distance of point from camera optical center.
◆ SetLens()
pure virtual |
[in] _lens Camera lens to set
