BaseWideAngleCamera< T > Class Template Reference
#include <BaseWideAngleCamera.hh>
virtual ~BaseWideAngleCamera ()
virtual common::ConnectionPtr ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
virtual void CreateWideAngleTexture ()
virtual const CameraLens & Lens () const override
 Get the camera lens used by this wide angle camera. More...
virtual math::Vector3d Project3d (const math::Vector3d &_pt) const override
 Project 3D world coordinates to screen coordinates. More...
virtual void SetLens (const CameraLens &_lens) override
 Set the camera lens to use for this wide angle camera. More...
- Public Member Functions inherited from WideAngleCamera
virtual ~WideAngleCamera ()
virtual ~Camera ()
virtual void Render ()=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
virtual ~BaseCamera ()
 Performs any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
 Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
 Remove all render passes from the camera. More...
 BaseCamera ()
CameraLens lens
 Camera lens used by this wide angle camera. More...
 Anti-aliasing. More...
double aspect = 1.3333333
 Aspect ratio. More...
double farClip = 1000.0
NodePtr followNode
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseWideAngleCamera()
◆ ~BaseWideAngleCamera()
◆ ConnectNewWideAngleFrame()
common::ConnectionPtr ConnectNewWideAngleFrame ( std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberNew camera listener callback
Implements WideAngleCamera.
Reimplemented in Ogre2WideAngleCamera, and OgreWideAngleCamera.
◆ CreateWideAngleTexture()
◆ Lens()
const CameraLens & Lens ( ) const
Camera lens set to this wide angle camera
◆ Project3d()
math::Vector3d Project3d ( const math::Vector3d &  _pt) const
[in]_pt3D world coordinates
Screen coordinates. Z is the distance of point from camera optical center.
References std::endl(), Scene::Engine(), gzerr, and RenderEngine::Name().
◆ SetLens()
void SetLens ( const CameraLens &  _lens)
[in]_lensCamera lens to set
◆ lens
CameraLens lens
