RenderEngine Class Referenceabstract
An abstract interface to a concrete render-engine. A RenderEngine is responsible for initializing a render-engine as well as creating, storing, and destroying scenes. More...
#include <gz/rendering/RenderEngine.hh>
virtual ~RenderEngine ()
virtual void AddResourcePath (const std::string &_path)=0
 Add path to media resource location. More...
virtual NativeWindowPtr CreateNativeWindow (const std::string &_winHandle, const uint32_t _width, const uint32_t _height, const double _ratio)=0
 Creates a basic native window. Note: This is useful when you need a basic single window with both great performance and compatibility. But e.g. creating more than one window may have additional complexities depending on OS and RenderSystem. More...
virtual ScenePtr CreateScene (const std::string &_name)=0
virtual ScenePtr CreateScene (unsigned int _id, const std::string &_name)=0
virtual void DestroyScene (ScenePtr _scene)=0
virtual void DestroySceneById (unsigned int _id)=0
virtual void DestroySceneByIndex (unsigned int _index)=0
virtual void DestroySceneByName (const std::string &_name)=0
virtual void DestroyScenes ()=0
virtual bool Fini ()=0
virtual rendering::GraphicsAPI GraphicsAPI () const =0
 Returns the GraphicsAPI currently in use. More...
virtual bool HasScene (ConstScenePtr _scene) const =0
virtual bool HasSceneId (unsigned int _id) const =0
virtual bool HasSceneName (const std::string &_name) const =0
virtual bool Headless () const =0
 Get headless mode. More...
virtual bool Init ()=0
virtual bool IsInitialized () const =0
virtual bool IsLoaded () const =0
virtual bool Load (const std::map< std::string, std::string > &_params={})=0
virtual RenderPassSystemPtr RenderPassSystem () const =0
virtual ScenePtr SceneById (unsigned int _id) const =0
virtual ScenePtr SceneByIndex (unsigned int _index) const =0
virtual ScenePtr SceneByName (const std::string &_name) const =0
virtual unsigned int SceneCount () const =0
virtual void SetHeadless (bool _headless)=0
◆ ~RenderEngine()
virtual ~RenderEngine ( )
◆ AddResourcePath()
virtual void AddResourcePath ( const std::string &  _path)
[in]_pathAbsolute path to resource location
Implemented in Ogre2RenderEngine, OgreRenderEngine, and BaseRenderEngine.
◆ CreateNativeWindow()
virtual NativeWindowPtr CreateNativeWindow ( const std::string &  _winHandle,
const double  _ratio
[in]_winHandleSee samples on what to fill in here
[in]_widthStarting width
[in]_heightStarting height
[in]_ratioDevice pixel ratio (typically needed for retina displays)
NativeWindow. It may be nullptr if the underlying engine hasn't implemented one
Implemented in Ogre2RenderEngine, and BaseRenderEngine.
◆ CreateScene() [1/2]
virtual ScenePtr CreateScene ( const std::string &  _name)
[in]_nameName of the new scene
The created scene
Implemented in BaseRenderEngine.
◆ CreateScene() [2/2]
virtual ScenePtr CreateScene ( unsigned int  _id,
[in]_idID of the new scene
The created scene
◆ DestroyScene()
virtual void DestroyScene ( ScenePtr  _scene)
[in]_sceneScene to be destroyed
◆ DestroySceneById()
virtual void DestroySceneById ( unsigned int  _id)
[in]_idID of the scene to destroy
◆ DestroySceneByIndex()
virtual void DestroySceneByIndex ( unsigned int  _index)
[in]_indexIndex of the scene to destroy
◆ DestroySceneByName()
virtual void DestroySceneByName ( const std::string &  _name)
[in]_nameName of the scene to destroy
◆ DestroyScenes()
virtual void DestroyScenes ( )
◆ Fini()
virtual bool Fini ( )
◆ GraphicsAPI()
virtual rendering::GraphicsAPI GraphicsAPI ( ) const
◆ HasScene()
virtual bool HasScene ( ConstScenePtr  _scene) const
[in]_sceneScene in question
True if the scene is managed by this render-engine
◆ HasSceneId()
virtual bool HasSceneId ( unsigned int  _id) const
[in]_idID of scene in question
True if this render-engine manages the specified scene
◆ HasSceneName()
virtual bool HasSceneName ( const std::string &  _name) const
[in]_nameName of scene in question
◆ Headless()
virtual bool Headless ( ) const
Get headless mode.
virtual bool Init ( )
True if the render-engine was successfully initialized
◆ IsEnabled()
◆ IsInitialized()
virtual bool IsInitialized ( ) const
True if the render-engine is initialized
◆ IsLoaded()
virtual bool IsLoaded ( ) const
True if the render-engine is loaded
◆ Load()
virtual bool Load ( const std::map< std::string, std::string > &  _params = {})
[in]_paramsParameters to be passed to the underlying rendering engine.
True if the render-engine was successfully loaded
◆ Name()
◆ RenderPassSystem()
virtual RenderPassSystemPtr RenderPassSystem ( ) const
◆ SceneById()
virtual ScenePtr SceneById ( unsigned int  _id) const
[in]_idID of scene to be retrieved
The specified scene
◆ SceneByIndex()
virtual ScenePtr SceneByIndex ( unsigned int  _index) const
[in]_indexIndex of scene, which is a number from 0 to SceneCount() - 1. Note that the index for a specific scene might change as other scenes are destroyed.
The specified scene
◆ SceneByName()
virtual ScenePtr SceneByName ( const std::string &  _name) const
[in]_nameName of scene to be retrieved
The specified scene
◆ SceneCount()
virtual unsigned int SceneCount ( ) const
The number of active scenes
◆ SetHeadless()
virtual void SetHeadless ( bool  _headless)
