#include <OgreRenderEngine.hh>
Public Types
enum  OgreRenderPathType {
  NONE = 0 , VERTEX = 1 , FORWARD = 2 , DEFERRED = 3 ,
  RENDER_PATH_COUNT
 The type of rendering path used by the rendering engine. More...
virtual ~OgreRenderEngine ()
void AddResourcePath (const std::string &_uri) override
 Add path to media resource location. More...
std::string CreateRenderWindow (const std::string &_handle, const unsigned int _width, const unsigned int _height, const double _ratio, const unsigned int _antiAliasing)
std::vector< unsigned int > FSAALevels () const
 Get a list of all supported FSAA levels for this render system. More...
virtual rendering::GraphicsAPI GraphicsAPI () const override
 Returns the GraphicsAPI currently in use. More...
virtual Ogre::Root * OgreRoot () const
OgreRenderPathType RenderPathType () const
- Public Member Functions inherited from BaseRenderEngine
virtual ~BaseRenderEngine ()
virtual NativeWindowPtr CreateNativeWindow (const std::string &, uint32_t, uint32_t, const double) override
 Creates a basic native window. Note: This is useful when you need a basic single window with both great performance and compatibility. But e.g. creating more than one window may have additional complexities depending on OS and RenderSystem. More...
virtual ScenePtr CreateScene (const std::string &_name) override
virtual ScenePtr CreateScene (unsigned int _id, const std::string &_name) override
virtual void DestroyScene (ScenePtr _scene) override
virtual void DestroySceneById (unsigned int _id) override
virtual void DestroySceneByIndex (unsigned int _index) override
virtual void DestroySceneByName (const std::string &_name) override
virtual void DestroyScenes () override
virtual bool Fini () override
virtual bool HasScene (ConstScenePtr _scene) const override
virtual bool HasSceneId (unsigned int _id) const override
virtual bool HasSceneName (const std::string &_name) const override
virtual bool Headless () const override
 Get headless mode. More...
virtual bool Init () override
virtual bool IsInitialized () const override
virtual bool IsLoaded () const override
virtual bool Load (const std::map< std::string, std::string > &_params={}) override
virtual RenderPassSystemPtr RenderPassSystem () const override
virtual ScenePtr SceneById (unsigned int _id) const override
virtual ScenePtr SceneByIndex (unsigned int _index) const override
virtual ScenePtr SceneByName (const std::string &_name) const override
virtual unsigned int SceneCount () const override
virtual void SetHeadless (bool _headless) override
- Public Member Functions inherited from RenderEngine
virtual ~RenderEngine ()
static OgreRenderEngine * Instance ()
 Get a pointer to the render engine. More...
virtual ScenePtr CreateSceneImpl (unsigned int _id, const std::string &_name) override
virtual bool InitImpl () override
virtual bool LoadImpl (const std::map< std::string, std::string > &_params) override
 Engine implementation of Load function. More...
virtual SceneStorePtr Scenes () const override
- Protected Member Functions inherited from BaseRenderEngine
 BaseRenderEngine ()
virtual unsigned int NextSceneId ()
virtual void PrepareScene (ScenePtr _scene)
- Protected Attributes inherited from BaseRenderEngine
bool initialized = false
bool isHeadless = false
bool loaded = false
unsigned int nextSceneId
RenderPassSystemPtr renderPassSystem
 Render pass system for this render engine. More...
std::vector< std::string > resourcePaths
 a list of paths that render engines use to locate their resources More...
std::string winID = ""
 ID from a external window. More...
◆ OgreRenderPathType
Enumerator
NONE
No rendering is done.
VERTEX
Most basic rendering, with least fidelity.
FORWARD
Utilizes the RTT shader system.
DEFERRED
Utilizes deferred rendering. Best fidelity.
RENDER_PATH_COUNT
Count of the rendering path enums.
◆ ~OgreRenderEngine()
virtual ~OgreRenderEngine ( )
◆ AddResourcePath()
void AddResourcePath ( const std::string &  _path)
[in]_pathAbsolute path to resource location
Reimplemented from BaseRenderEngine.
◆ CreateRenderWindow()
std::string CreateRenderWindow ( const std::string &  _handle,
◆ CreateSceneImpl()
virtual ScenePtr CreateSceneImpl ( unsigned int  _id,
const std::string &  _name
Implements BaseRenderEngine.
◆ FSAALevels()
std::vector<unsigned int> FSAALevels ( ) const
a list of FSAA levels
◆ GraphicsAPI()
virtual rendering::GraphicsAPI GraphicsAPI ( ) const
◆ InitImpl()
virtual bool InitImpl ( )
◆ Instance()
static OgreRenderEngine* Instance ( )
static
◆ IsEnabled()
◆ LoadImpl()
virtual bool LoadImpl ( const std::map< std::string, std::string > &  _params)
[in]_paramsParameters to be passed to the render engine. Current accepts the following parameters and values: "useCurrentGLContext" : "1" or "0". Use current OpenGL context for rendering
◆ Name()
The render-engine name
Implements RenderEngine.
◆ OgreRoot()
virtual Ogre::Root* OgreRoot ( ) const
◆ RenderPathType()
OgreRenderPathType RenderPathType ( ) const
◆ Scenes()
virtual SceneStorePtr Scenes ( ) const
