| virtual | ~OgreWideAngleCamera () |
| | Destructor. More...
| void | AddRenderPass (const RenderPassPtr &_pass) override |
| common::ConnectionPtr | ConnectNewWideAngleFrame (std::function< void(const unsigned char *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override |
| void | Copy (Image &_image) const override |
| virtual void | CreateRenderTexture () |
| | Create a texture. More...
| unsigned int | EnvTextureSize () const |
| | Gets the environment texture size. More...
| std::vector< Ogre::Camera * > | OgreEnvCameras () const |
| | Get the list of ogre cameras used to create the cube map for generating the wide angle camera image. More...
| | Render the camera. More...
| math::Vector3d | Project3d (const math::Vector3d &_pt) const override |
| | Project 3D world coordinates to screen coordinates. More...
| | Remove all render passes from the camera. More...
| void | RemoveRenderPass (const RenderPassPtr &_pass) override |
| | Implementation of the render call. More...
| bool | SetBackgroundColor (const math::Color &_color) |
| | Set the background color of the camera. More...
| void | SetEnvTextureSize (int _size) |
| | Sets environment texture size. More...
| void | SetUniformVariables (Ogre::Pass *_pass, float _ratio, float _hfov) |
| | Set uniform variables of a shader for the provided material technique pass. More...
| virtual | ~BaseWideAngleCamera () |
| | Destructor. More...
| virtual const CameraLens & | Lens () const override |
| | Get the camera lens used by this wide angle camera. More...
| virtual void | SetLens (const CameraLens &_lens) override |
| | Set the camera lens to use for this wide angle camera. More...
| virtual | ~WideAngleCamera () |
| | Destructor. More...
| virtual | ~Camera () |
| | Destructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
| virtual | ~BaseCamera () |
| | Right now this is Vulkan-only. This function needs to be called after rendering, and before handling the texture pointer (i.e. by calling RenderTextureMetalId()) so that external APIs (e.g. Qt) can sample the texture. More...
| virtual | ~OgreSensor () |
| virtual | ~BaseSensor () |
| virtual | ~OgreNode () |
| virtual | ~BaseNode () |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
