RenderTarget Class Referenceabstract
#include <gz/rendering/RenderTarget.hh>
virtual ~RenderTarget ()
virtual bool Reinterpretable () const =0
 See SetFormat() More...
 Remove all render passes from the render target. More...
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false)=0
◆ ~RenderTarget()
virtual ~RenderTarget ( )
◆ AddRenderPass()
Implemented in Ogre2RenderTexture, BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, and BaseRenderTarget< OgreObject >.
Referenced by BaseCamera< T >::AddRenderPass().
◆ BackgroundColor()
Implemented in Ogre2RenderTarget, OgreRenderTarget, BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, and BaseRenderTarget< OgreObject >.
◆ Copy()
Implemented in Ogre2RenderTarget, and OgreRenderTarget.
Referenced by BaseCamera< T >::Copy().
◆ Format()
virtual PixelFormat Format ( ) const
Render target format
Implemented in BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, and BaseRenderTarget< OgreObject >.
Referenced by BaseCamera< T >::ImageFormat().
◆ Height()
virtual unsigned int Height ( ) const
Referenced by BaseCamera< T >::ImageHeight().
virtual void PreRender ( const CameraPtr &  _camera)
Referenced by BaseCamera< T >::PreRender().
◆ Reinterpretable()
virtual bool Reinterpretable ( ) const
See SetFormat()
True if format is reinterpretable
◆ RemoveAllRenderPasses()
virtual void RemoveAllRenderPasses ( )
◆ RemoveRenderPass()
Referenced by BaseCamera< T >::RemoveRenderPass().
◆ RenderPassByIndex()
Referenced by BaseCamera< T >::RenderPassByIndex().
◆ RenderPassCount()
Referenced by BaseCamera< T >::RenderPassCount().
◆ SetFormat()
virtual void SetFormat ( PixelFormat  _format,
bool  _reinterpretable = false
[in]_formatNew target format
[in]_reinterpretablewhether the RenderTarget will be reinterpreted to another format (e.g. from RGBA8_UNORM to/from RGBA8_UNORM_SRGB)
Referenced by BaseCamera< T >::SetImageFormat().
◆ SetHeight()
virtual void SetHeight ( const unsigned int  _height)
Referenced by BaseCamera< T >::SetImageHeight().
◆ SetWidth()
virtual void SetWidth ( const unsigned int  _width)
Referenced by BaseCamera< T >::SetImageWidth().
◆ Width()
virtual unsigned int Width ( ) const
Referenced by BaseCamera< T >::ImageWidth().
