virtual ~OgreRenderTarget ()
virtual void Destroy () override=0
virtual void Render ()
virtual Ogre::RenderTarget * RenderTarget () const =0
 Set visibility mask for the viewport associated with this render target. More...
 BaseRenderTarget ()
 ~BaseRenderTarget () override
virtual bool Reinterpretable () const override
 See SetFormat() More...
 Remove all render passes from the render target. More...
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false) override
virtual ~RenderTarget ()
 OgreRenderTarget ()
void RebuildMaterial ()
virtual void RebuildTarget ()=0
virtual void Rebuild ()
virtual void Init ()
unsigned int antiAliasing = 4
bool colorDirty = true
 visibility mask associated with this render target More...
PixelFormat format
unsigned int height
bool reinterpretable
bool renderPassDirty
bool targetDirty
unsigned int width
◆ OgreRenderTarget()
OgreRenderTarget ( )
◆ ~OgreRenderTarget()
virtual ~OgreRenderTarget ( )
◆ AddViewport()
Ogre::Viewport* AddViewport ( Ogre::Camera *  _viewport)
◆ AntiAliasing()
◆ BackgroundColor()
Reimplemented from BaseRenderTarget< OgreObject >.
◆ Camera()
virtual Ogre::Camera* Camera ( ) const
◆ Copy()
Implements RenderTarget.
overridepure virtual
Implemented in OgreRenderTexture, and OgreRenderWindow.
◆ PostRender()
virtual void PostRender ( )
Reimplemented in OgreRenderTexture.
◆ RebuildImpl()
virtual void RebuildImpl ( )
◆ RebuildMaterial()
void RebuildMaterial ( )
OgreRenderTarget::RebuildImpl()
BaseRenderTarget::Rebuild()
◆ RebuildTarget()
protectedpure virtual
◆ RebuildViewport()
virtual void RebuildViewport ( )
◆ Render()
virtual void Render ( )
◆ RenderTarget()
◆ SetAntiAliasing()
virtual void SetAntiAliasing ( unsigned int  _aa)
◆ SetAutoUpdated()
void SetAutoUpdated ( const bool  _value)
◆ SetBackgroundColor()
virtual void SetBackgroundColor ( math::Color  _color)
◆ SetCamera()
virtual void SetCamera ( Ogre::Camera *  _camera)
◆ SetMaterial()
void SetMaterial ( MaterialPtr  _material)
[in]_materialThe material to render
◆ SetUpdate()
void SetUpdate ( const bool  _value)
◆ SetVisibilityMask()
[in]_maskVisibility mask
◆ UpdateBackgroundColor()
virtual void UpdateBackgroundColor ( )
◆ UpdateRenderPassChain()
virtual void UpdateRenderPassChain ( )
◆ Viewport()
Ogre::Viewport* Viewport ( const int  _viewportId) const
◆ antiAliasing
◆ colorDirty
◆ material
◆ materialApplicator
◆ ogreBackgroundColor
◆ ogreCamera
◆ ogreViewport
Ogre::Viewport* ogreViewport = nullptr
◆ visibilityMask
