BaseRenderTarget< T > Class Template Referenceabstract
 BaseRenderTarget ()
 ~BaseRenderTarget () override
virtual bool Reinterpretable () const override
 See SetFormat() More...
 Remove all render passes from the render target. More...
virtual void SetFormat (PixelFormat _format, bool _reinterpretable=false) override
virtual ~RenderTarget ()
virtual void Rebuild ()
virtual void RebuildImpl ()=0
PixelFormat format = PF_UNKNOWN
unsigned int height = 0u
bool reinterpretable = false
bool renderPassDirty = false
bool targetDirty = true
unsigned int width = 0u
◆ BaseRenderTarget()
◆ ~BaseRenderTarget()
~BaseRenderTarget
◆ AddRenderPass()
Implements RenderTarget.
Reimplemented in Ogre2RenderTexture.
◆ BackgroundColor()
math::Color BackgroundColor ( ) const
Reimplemented in Ogre2RenderTarget, and OgreRenderTarget.
References Scene::BackgroundColor().
◆ Format()
PixelFormat Format ( ) const
Render target format
◆ Height()
unsigned int Height ( ) const
◆ PostRender()
void PostRender ( )
Reimplemented in Ogre2RenderTexture, Ogre2RenderTarget, OgreRenderTexture, and OgreRenderTarget.
◆ PreRender() [1/2]
void PreRender ( )
◆ PreRender() [2/2]
void PreRender ( const CameraPtr &  _camera)
◆ Rebuild()
void Rebuild
◆ RebuildImpl()
virtual void RebuildImpl ( )
protectedpure virtual
Implemented in Ogre2RenderTarget, and OgreRenderTarget.
◆ Reinterpretable()
bool Reinterpretable ( ) const
See SetFormat()
True if format is reinterpretable
◆ RemoveAllRenderPasses()
void RemoveAllRenderPasses ( )
◆ RemoveRenderPass()
References std::find().
◆ RenderPassByIndex()
References std::endl(), and gzerr.
◆ RenderPassCount()
◆ SetFormat()
void SetFormat ( PixelFormat  _format,
bool  _reinterpretable = false
[in]_formatNew target format
[in]_reinterpretablewhether the RenderTarget will be reinterpreted to another format (e.g. from RGBA8_UNORM to/from RGBA8_UNORM_SRGB)
References PixelUtil::Sanitize().
◆ SetHeight()
void SetHeight ( const unsigned int  _height)
◆ SetWidth()
void SetWidth ( const unsigned int  _width)
◆ Width()
unsigned int Width ( ) const
◆ format
◆ height
◆ reinterpretable
◆ renderPassDirty
◆ renderPasses
std::vector<RenderPassPtr> renderPasses
◆ targetDirty
◆ width
